post #46 of Old 01-28-2014, 07:42 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Stock front, super 35 with Detroit locker and 4.56s for gears turning 35s.
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline
post #47 of Old 01-29-2014, 04:10 AM
96zjlaredo
Cutting the coil springs IS NOT going to give you more flex, in fact you will get less. PHYSICS my friend PHYSICS.
If a tree falls in the woods then farts, Do the other trees smell it?
96zjlaredo is offline
post #48 of Old 03-13-2014, 03:25 PM
straight6zj
hunter what shocks are you running on your rig.I am just about to b at 5.5 on all adj upper n lowers, just deciding on what shocks to get. pretty much best bang for the buck kinda deal thanks
straight6zj is offline
post #49 of Old 03-13-2014, 05:23 PM
WhiteOut
WhiteOut's Avatar
Bilsteins.
Sent from AutoGuide.com App
WhiteOut is offline
post #50 of Old 04-26-2014, 09:14 PM
dorrmann27
I'm about to have between 5-5.5 " on my Zj with all 8 adj. CA's and quick discos up front. I've got 4.5" RE spring up front and the are only netting 1.25" lift passenger and .75" on driver side. I did the front to rear and noticed rear wheels are out of alignment but front looks alright. My question is - sort of along this topic line- what am I missing for 5.5" of lift? Do I need an adj. Track bar and bracket for the rear? And any ideas what's going on with the front causing my springs to stay compressed? Also track bar?
Thanks for all the input
1993 Jeep Grand Cherokee Limited 4.0L--Dayton Timberline A/T 31"
dorrmann27 is offline
Torn between 4 inch and 4.5 inch lift for my ZJ givemeazj ZJ Grand Cherokee Forum 21 08-07-2011 09:42 PM
I have a question about shocks and 2 inch lift? madi05 ZJ Grand Cherokee Forum 15 10-19-2009 07:40 PM
question about alinement specs for 97 GC with 4.5 inch lift??? Bobbert ZJ Grand Cherokee Forum 4 05-30-2009 03:04 PM
2 Inch lift vs. 2 Inch Spacers jeep_05 WK Grand Cherokee & XK Commander Forum 19 06-06-2008 01:57 PM
Question about 2 inch BB lift and shocks jad_johnson ZJ Grand Cherokee Forum 2 01-08-2007 12:59 PM
You may not post new threads
You may not post replies
