ZJ 5.5 inch lift question - Page 2 - JeepForum.com
post #16 of 50 Old 01-15-2008, 08:15 PM
SkyjacktZJ
SkyjacktZJ's Avatar
2015 WK
I'm running a similar setup as Hunter. Got no complaints.
2015 JGC Altitude Edition
Customer Preferred Package 23Z
Granite Crystal Metallic Clearcoat
SkyjacktZJ is offline
post #17 of 50 Old 01-15-2008, 10:06 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Note to thread poster. If the guy telling you to cut a coil isn't running cut coils on his vehicle, don't do it.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #18 of 50 Old 01-16-2008, 01:58 AM
95ZJ
i wasnt telling him he should do it, just saying theres nothign wrong with doing it. i dunno why u would want to cut them anyways.
can u even cut the GC coils? cause i thought that the top and bottom coils were smaller than the middle coils, i may be wrong though i havent looked at mine for a bit lol
95 GC limited
-lifted
-locked F+R
-33" tsl's
95ZJ is offline
post #19 of 50 Old 01-16-2008, 06:28 AM Thread Starter
BLU88
Didn't mess with it last night. To busy chasing down bolts after work. I'll see if I can get some work done tonight after I get home. I Want to try and make this work. I am just curious as to what makes cutting coils so dangerous. All i am thinking of doing is cutting off of the bottom maybe one coil. I know that my change the spring rate but I figure that may give a little more flex. I am not going to weld or stack coils like I've seen some do
Lurking and asking lots and lots of questions..........
__________
/__l_l_,\____\,____
l_---l_l__l----( )jeep( )
._(o)_)__(o)_)--o-)_)
BLU88 is offline
post #20 of 50 Old 01-16-2008, 10:09 AM
sandman
hmmm, cutting coils. you should try hondaforums for this one. lol.... i say leave them. are you running stock control arms? 6in is fine on short arms but all 8 or at least 6 of them need to be adjustable. or if your going for the cheap put your front coils in the rear and put these up front http://www.ironrockoffroad.com/Merch..._Code=IR-Z3FSP
1993 Jeep ZJ. 4.0
sandman is offline
post #21 of 50 Old 01-16-2008, 10:41 AM
WJChris
WJChris's Avatar
the thought about cutting coils is the heat to cut them (as long as you use a cutoff wheel you will be fine)
and that most new cars springs are progressive, if you cut coils, you ruin them.
On an F150, I doubt they are progressive. You can tell they are progresive if the coils get closer together at the ends.
WJChris is offline
post #22 of 50 Old 01-16-2008, 11:22 AM
Darthteddy
1955 M-38
I didnt realize that F150 coils would fit on a GC???
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #23 of 50 Old 01-16-2008, 11:42 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i got a guy in my town with F150 coils and REALY big leaf springs ,on his XJ. he has done frame stiffeners, and he jumps and preerunners that thing like heel, realy cool to watach em.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #24 of 50 Old 01-16-2008, 01:43 PM
Darthteddy
1955 M-38
Hrm...So F-150 springs are the same size but stiffer? I wouldnt care to do anything like jeep speed....but a little jumping is allways fun.
post #25 of 50 Old 01-16-2008, 02:35 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yeah, jumping a Grand with a dana 30 up front is NOT VERY SMART. You'll break the axle or worse.
BTW, nice thread hi-jack. If you aren't contributing to the 5.5 inch thread, go elsewhere.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #26 of 50 Old 01-16-2008, 03:25 PM
MuddyLuxury
MuddyLuxury's Avatar
i kno i have a dub, but at 4in on short arms the ride was rough, now, at 6.5 on LAs, it rides like a caddy in straight lines
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #27 of 50 Old 01-16-2008, 04:04 PM
CLNinja
CLNinja's Avatar
cutting coils is NEVER a smart or safe idea
if thats what you plan on doing... im glad you dont live in Colorado
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #28 of 50 Old 01-24-2008, 03:48 PM
Marauder.45
This thread is good info. Thanks guys. Sorry if this is a little hi-jack, pm me your post if needed. I just did front axles and new shocks up front to cure clunks over bumps. On the test ride there was still a little clunk. So come to find out front upper and lower CAs are toast. I have to redo them. Rears are cool, but might as well do it all at once.
So if I was shooting for 3.5" or less, staying with short or stock length is fine? What is the generally popular adjustable brand? I've been eying the IRO 3.5, is there a good combo people are running with that?
Thanks for the help.
1998 ZJ 5.9L Stock............
For now ;)
Marauder.45 is offline
post #29 of 50 Old 01-24-2008, 07:46 PM
turbo_jb
So are you saying F150 coils are the same diam. as Zjs are? how much of a lift did that end up to be?
turbo_jb is offline
post #30 of 50 Old 01-24-2008, 09:22 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
turbo jb,
you need to stick to reading what 99% of the lifted Grand guys have used. You've PMed me about coils. Did you ever PM skyjacktZJ?
This is not a F150 coil or cutting coil thread. Stop hi-jacking.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
Torn between 4 inch and 4.5 inch lift for my ZJ givemeazj ZJ Grand Cherokee Forum 21 08-07-2011 09:42 PM
I have a question about shocks and 2 inch lift? madi05 ZJ Grand Cherokee Forum 15 10-19-2009 07:40 PM
question about alinement specs for 97 GC with 4.5 inch lift??? Bobbert ZJ Grand Cherokee Forum 4 05-30-2009 03:04 PM
2 Inch lift vs. 2 Inch Spacers jeep_05 WK Grand Cherokee & XK Commander Forum 19 06-06-2008 01:57 PM
Question about 2 inch BB lift and shocks jad_johnson ZJ Grand Cherokee Forum 2 01-08-2007 12:59 PM
