ZJ 4.0L vacuum checkvalve install location - JeepForum.com
post #1 of 2 Old 07-01-2004, 06:46 AM Thread Starter
97RedBird
2009 MK Compass
I just purchased the vacuum checkvalve canister for my 96 4.0L to solve the issue when you go up a steep or long incline the A/C switches to the defrost and back to A/C as soon as you crest the hill.
Where does this checkvalve go. It has a rubber 90 degree elbow that is to large to fit on anywhere I could find in the engine compartment. I thought it would install on the HVAC leg of the vacuum line, but it doesn't work without some engineering and another 6 inches of vacuum line. Does it install under the dash closer to the HVAC door? The canister is about 2-3 inches long and 1" in diameter. part #33321
Thanks!
97RedBird is offline
post #2 of 2 Old 07-02-2004, 07:24 AM Thread Starter
97RedBird
2009 MK Compass
Couldn't find the TSB yesterday. Here it is for anyone else that needs the fix. The vacuum canister was only $6.50 from the dealership.
http://dodgeram.info/tsb/1996/24-01-96a.htm
5.2 Vacuum Line Location(easy inquiry) ddeadserious ZJ Grand Cherokee Forum 20 07-19-2016 11:07 AM
ZJ radiator install, best spark plugs, bumper guard install doccjp ZJ Grand Cherokee Forum 10 09-30-2010 07:20 PM
Vacuum Leak 1997 Laredo Dash Vacuum Lines twmattox ZJ Grand Cherokee Forum 4 11-17-2008 08:34 AM
Uconnect picture and install location Bville-Bud WK Grand Cherokee & XK Commander Forum 4 10-20-2008 07:30 PM
Vacuum reservoir location theone13 ZJ Grand Cherokee Forum 3 05-19-2005 06:46 PM
