ZJ 4.0L Serpentine belt remove and install help - JeepForum.com
post #1 of 30 Old 01-25-2010, 12:59 PM Thread Starter
NeverL8
Hi I just did all the maintaint on the car, that I can think off. I take car to car care clinic for 28 point inspection, they told me that I need Serpentine belt and 2 rear tires . Good to know that everything arite . So here I am, just bought a gator back from autozone ( the reason I chose this belt its, because I been using it on all my family car for over 5 year now, none need replace ). I usualy pay some one to do it, but I want save some money atm. How do you remove and install this belt and the way its look, do I need to remove the fan ? thanks
NeverL8 is offline
post #2 of 30 Old 01-25-2010, 01:23 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
The 4.0 has the serpentine tension adjustment built into the power steering pump bracket. All you have to do is loosen the idler pulley bolt below the power steering pump and loosen the tensioner adjuster. Reverse for installation.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 30 Old 01-25-2010, 02:03 PM Thread Starter
NeverL8
the pix worth 1000 word, thanks
NeverL8 is offline
post #4 of 30 Old 01-25-2010, 05:50 PM
Mike97ZJ
And just be patient and make sure you get the routing right.
And maybe I'm just "special", but I had a heck of a time getting mine back on...it kept getting snagged on the fan. I had to walk away from it and come back later to finish it, I was getting too aggravated and needed a cooldown.
Mike97ZJ is offline
post #5 of 30 Old 01-25-2010, 06:01 PM
Hexonut
Hexonut is offline
post #6 of 30 Old 01-25-2010, 11:21 PM Thread Starter
NeverL8
im I doing right ? I tight up the idler puller and tight the adjust bolt, first the belt is making squeak noise, then I tight the adjust bolt down, then it make less speak noise, then I tight the bolt down again, then the noise went away, I push the belt down and it kinda tight but not too tight, the belt make no squeak noise so i think I did it right. I am do it right ? thanks
NeverL8 is offline
post #7 of 30 Old 01-25-2010, 11:31 PM
torchd
2003 WJ
goodyear gatorback belts are good belts
torchd is offline
post #8 of 30 Old 01-25-2010, 11:34 PM Thread Starter
NeverL8
the old belt was a good year gator back also, old belt make no noise, but sinceI just bought this jeep and i seen a little crack, I might as well replace it, but keep the old belt just incase something happent on the road . but please answer my preview question, as long the belt make no squeak noise, im doing it right ?
NeverL8 is offline
post #9 of 30 Old 02-13-2011, 03:29 PM
CTJeepWJ
2010 JK Wrangler
I used the image in post number 2 and it took about 20 minutes on my buddy's ZJ. Thanks guys!
-Ed
BLACK JEEP SOCIETY
2010 JK & 2004 WJ
CTJeepWJ is offline
post #10 of 30 Old 07-30-2011, 04:51 AM
Bale
My new belt seems to short
Can't get it on the final (power steering pump) pulley, even with the idler in the bottom position, or with the belt off the idler. I think it's routed correctly.
Have I got the wrong belt? It's an Infinity brand, DY923K6, 5060923 (6PK2344).
1998 ZG (ZJ) Grand Cherokee Ltd, 4L 4x4
Bale is offline
post #11 of 30 Old 07-30-2011, 07:32 AM
ZeeJay1997
Did you check it against the diagram under the hood?
ZeeJay1997 is offline
post #12 of 30 Old 07-30-2011, 11:06 AM
Bale
Yes. And getting the old belt installed again is no problem. Comparing the belts the new one is clearly shorter than the old one. About half an inch longer and it would fit.
Bale is offline
post #13 of 30 Old 07-30-2011, 04:40 PM
coachdmo
belts stretch over time, that's why the old one appears longer. You need to loosen the tensioner as much as you can to get it on.
coachdmo is offline
post #14 of 30 Old 07-30-2011, 04:54 PM
Oldfrog
2007 WK
The gator back might last a while, but what you really want is a GATES belt on that 4.0. It costs more, but worth it. Broken two of those gator backs on mine. Never again. The Gates is a much stronger belt.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #15 of 30 Old 07-31-2011, 01:43 AM
classicmetalman
You should be fine
Sounds like you got the wrong belt
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
How to remove serpentine belt/alternator ZJ 4.0 1997 davooo ZJ Grand Cherokee Forum 9 04-28-2009 01:32 AM
Serpentine belt for 04 mmacnish ZJ Grand Cherokee Forum 5 06-22-2008 01:42 PM
Serpentine Belt Nofear6372 ZJ Grand Cherokee Forum 8 05-16-2008 10:41 AM
Serpentine Belt LargeFather ZJ Grand Cherokee Forum 8 09-01-2007 08:56 AM
Do i need a new serpentine belt? 98ZJBlack ZJ Grand Cherokee Forum 7 10-06-2004 11:55 AM
