ZJ 4.0 starting problems - JeepForum.com
post #1 of 7 Old 10-29-2011, 10:19 AM Thread Starter
giacomo.m
Hi all,
I have a ZJ 4.0 1997 with long crank problems,after the third or fourth time the jeep start.
I replaced the fuel pump and pressure regulator, but nothing has changed.
help,help
thank you
Giacomo
giacomo.m is offline
post #2 of 7 Old 10-30-2011, 12:30 AM
Oldfrog
2007 WK
Start by cleaning the throttle body with some spray cleaner. Your IAC may be sticking.
Next time you start it, turn the key to "on" but not start....listen for the fuel pump to run for a few seconds. Then turn it off and do it again....but this time, go ahead and start it.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 7 Old 10-30-2011, 02:28 AM Thread Starter
giacomo.m
Thank you Oldfrog,
so if you tell me what happens is just the throttle body dirty ?
but it could also be a check valve in the fuel pump assembly ?
Giacomo
post #4 of 7 Old 10-30-2011, 10:18 AM
JasonStebbins
Have you replaced the fuel filter? Are the battery terminals tight? Try spraying some carb cleaner in the intake, and like Frog said, clean the IAC. It's very simple to do.
When was the last time you did a full tuneup? Plugs/wires/cap/rotor etc...
Poop
JasonStebbins is offline
post #5 of 7 Old 10-30-2011, 11:20 AM Thread Starter
giacomo.m
Hi Jason
new fuel filter
plugs/wires I replaced a year ago.
thank you
Giacomo
post #6 of 7 Old 10-30-2011, 06:22 PM
Pugulis
Just because you replace the wires a year ago, doesn't mean they are not bad. Sometimes cheeper wires can go bad real fast. Let me ask you, did the weather just start to get colder (or even freezing)? This would point me to the wires.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline
post #7 of 7 Old 10-31-2011, 01:23 AM Thread Starter
giacomo.m
Hi Pugulis.
maybe you're right, but it seems strange to me.
Now the temperature at night in Rome is about 15/16 ° C
thank you
Giacomo
Starting Problems CTkid ZJ Grand Cherokee Forum 1 08-26-2011 12:15 PM
starting problems gdoughtie ZJ Grand Cherokee Forum 7 08-14-2011 04:27 AM
ZJ problems starting Grbeast001 ZJ Grand Cherokee Forum 2 04-20-2011 10:06 AM
'04 WJ (4.7HO) - Starting problems... Shinner ZJ Grand Cherokee Forum 7 06-23-2008 01:28 PM
Starting problems djd24 ZJ Grand Cherokee Forum 8 06-20-2006 07:23 AM
