ZJ 3" spring lift - JeepForum.com
post #1 of 9 Old 12-27-2006, 12:59 AM Thread Starter
ericheineman01
1994 ZJ
Location: Kent, Washington -- 20 miles south of Seattle
ZJ 3" spring lift
I got a Teraflex 3" coil supsension lift for christmas me and my dad are doing the installation tomorrow and I just need to know which type of spring compressors I should rent. Shucks has the internal coil spring compressors and the external strut compressors. I think I heard somewhere that the strut compressors are a lot easier to work with. Which one should I get?
5.2 V8, 249 :( , K&N FIPK Gen II Intake, Flowmaster 40 Series,
(2) 80w Walmart Fogs, (4) 100w roof lights, (2) 50w rock lights, Upgraded back up lights,
3" Teraflex Lift, OME SS, 265/75/15 Toyo Open Country A/Ts, Taurus E-Fan conversion, 150A ND Alternator, Kevin's Radiator Support/Tow Points, T-Case Skid Plate
(not quite ready yet...) and
ericheineman01 is offline
post #2 of 9 Old 12-27-2006, 03:39 AM
RedGrand
External is only one that will work, no room in there for the internal. Good luck and post some pics...
RedGrand is offline
post #3 of 9 Old 12-27-2006, 07:18 AM
98zjdave
Good luck and definately get the outside spring compressors. I made a mistake and picked up the inside, and boy was I frustrated.
98zjdave is offline
post #4 of 9 Old 12-27-2006, 08:16 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Good info there. Make sure to get an alignment after the lift. That is the number one cause of Death Wobble in ZJs.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 9 Old 12-27-2006, 08:58 AM
gunthagunth
gunthagunth's Avatar
Try and get the coils in without the compressors first. Its rather easy if you jack the body up as high as you can and put jackstands or jackstands with sturdy blocks under them holding up the body. They you use a floor jack to drop the axle as low as it can go after you disconnect the lower control arms, shocks, brake calipers, rotors, antiswaybar, and you may need to remove the steering setup from the knuckles and pitman arm and also disconnect the trackbar from the axle. You should be able to step on the hub and remove the old coils and with someones help step on the hub again and put the new coil in. Another thing that helps is a bottle jack wedged up in there pushing the axle down if you need a extra inch. Its easier said than done but it is much easier than screwing around with the compressors. Once you get them in there its tight quarters and you dont want a compessed coil coming back in your face .
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #6 of 9 Old 12-27-2006, 11:28 AM Thread Starter
ericheineman01
1994 ZJ
Alrighty, external compressors it is. I'll sure be back here if i have any trouble and will definately post some pics. Thanks for the help.
post #7 of 9 Old 12-27-2006, 09:03 PM
platinum5.9
2003 WJ
Can't wait for pics! Where did you get the kit and how was the price?
platinum5.9 is offline
post #8 of 9 Old 12-28-2006, 01:44 AM Thread Starter
ericheineman01
1994 ZJ
It took me and my dad about 6 hours to do the entire back end, (clearerly we are skilled mechanics) we've given up for the night and will hopefully finish it tomorrow. I'm just a little concerned about how close the new sway bar link is to the wheel. About 1/4"
Heres a pic of the back side with the rock lights on
My dad got me the Teraflex kit for christmas, he bought it at a local 4x4 shop it was probly around $500-$600.
post #9 of 9 Old 12-28-2006, 08:53 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
When you get your new aftermarket wheels with less backspacing than stock say 3.75 to 4 inches, that swaybar endlink won't be a problem.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
Uncompressed spring length for 3-4" Lift Raitinger ZJ Grand Cherokee Forum 27 05-19-2009 11:56 PM
2.5" wj spring lift? StoveBolt ZJ Grand Cherokee Forum 23 03-20-2007 07:48 PM
6" lift spring measurement for WJ FearTheDentist ZJ Grand Cherokee Forum 41 07-27-2006 02:37 PM
I6 front spring to rear---> 2.5" of lift? bethsjeep ZJ Grand Cherokee Forum 30 02-23-2006 08:49 PM
Who Sells WJ spring for a 2" lift or less ? 2Grand4s ZJ Grand Cherokee Forum 3 02-23-2005 10:07 PM
