zj 3.5 inch lift front cv shaft - Page 2 - JeepForum.com
post #16 of 19 Old 11-02-2013, 09:09 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The CV joint has to point perfectly at the ring gear. In other words they need to be perpendicular.
You may or may not be able to achieve that with the stock control arms cambolt adjustment.
HighLonesome is offline
post #17 of 19 Old 11-22-2013, 04:57 AM
bjorn17
I also happen to have a 3"-3.5" lift on my ZJ. Stock front CV driveshaft.
What is exactly the reasons behind the front driveshaft exploding? Is it because the CV unit does not allow the driveshaft to expand and compress enough or what?
I am trying to understand what I should or should not do. E.g. can I use WJ front lower CA or not. They will move the front axle a bit more forward, which is pefect for the lift but I am not sure how good it will be for the CV driveshaft. It will need to expand more in length and it will not be at such a good angle anymore.
Ideas?
bjorn17 is offline
post #18 of 19 Old 11-26-2013, 09:16 PM
dougmorgan99
Originally Posted by WhiteOut View Post
Lol, 5.5" on stock arms. The reason it didn't grenade is because he has less travel than stock.
ROFL, there may be a lot of truth to that WhiteOut. But man would that thing flexed out really well with the sway-bar disconnected. I'll have to find a pic with it flexed and post it... Actually I misspoke, he did have RC fixed lower control arms from their 3.5" lift kit. He also added 2" BB blocks on it but still had his stock upper arms. It confounded me why he set it up this way but I guess each Jeep owner has a right to do what he wants to do despite conventional wisdom. Either way, his CV front driveshaft survived...
dougmorgan99 is offline
post #19 of 19 Old 01-08-2014, 07:27 PM
po0dingles
po0dingles is offline
cv driveshaft , rough country
5 inch lift upper front c/a length coopdc ZJ Grand Cherokee Forum 1 09-03-2010 04:10 PM
95 ZJ - 4 inch RC lift- drive shaft issue WaffelNinja ZJ Grand Cherokee Forum 6 07-12-2010 03:15 PM
Front Drive Shaft Problem with lift kit KDXFreestyle200 ZJ Grand Cherokee Forum 3 09-12-2009 07:28 PM
Loose ratttling in front end after 2 inch lift intalled Jbirdjeep ZJ Grand Cherokee Forum 0 04-28-2009 07:05 PM
What Kind of Front Drive Shaft/Lift Kit ? Bosshound ZJ Grand Cherokee Forum 7 02-14-2005 10:43 PM
