zj 1997 info center problem - JeepForum.com
post #1 of 8 Old 08-30-2010, 06:43 PM Thread Starter
dyurik
has anyone heard of the info center on the 1997 zj going out and smoking. we found a replacement but i was wondering if there is a secondary problem that causes the info center to fry. also does anyone know if there is a way to by pass the info center so the radio will work but not have the problem with the info center
dyurik is offline
post #2 of 8 Old 08-31-2010, 08:22 AM
madmax4tex
I am having the same problem, any help?
madmax4tex is offline
post #3 of 8 Old 08-31-2010, 04:53 PM Thread Starter
dyurik
my guess so far
so far i figure that just buying a replacement should fix it but i'm not sure if they all have the same problem or not.
dyurik is offline
post #4 of 8 Old 08-31-2010, 09:37 PM
freakinheep89
do you have the digital VIC or graphic display
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 8 Old 09-01-2010, 10:03 PM
madmax4tex
No completely dead :-(
post #6 of 8 Old 09-01-2010, 11:03 PM
freakinheep89
i meant do you have the VIC or graphic display
VIC= digital screen with green letters(similar to a calculator) and flashing lights and what not
Graphic display= gray panel with picture of jeep that has flashing lights
TJ-
post #7 of 8 Old 09-03-2010, 11:00 PM
madmax4tex
Graphic display, it started to display all dots then went black.
post #8 of 8 Old 09-03-2010, 11:10 PM
freakinheep89
how did it go black, the graphic display has a permanent pic of the jeep. i think you might still have them confused, sounds like the VIC. they are prone to going out, mostly cause of loose connectors.
TJ-
1997 , zj
Info Center brake light problem chipflyer ZJ Grand Cherokee Forum 2 09-15-2010 10:17 AM
Vehicle Info center problem,shuts off then flashes Machine1964 ZJ Grand Cherokee Forum 5 11-25-2009 12:22 PM
98 Limited 5.9 Overhead Info Center Problem CULate ZJ Grand Cherokee Forum 4 07-10-2009 02:02 AM
need new info center wassy ZJ Grand Cherokee Forum 3 02-01-2007 04:49 PM
Electircal Problem w/Vehicle Info Center Charlie93GC ZJ Grand Cherokee Forum 3 01-07-2002 02:49 PM
