Zj 1 ton steering?'s - Page 2 - JeepForum.com
post #16 of 35 Old 04-19-2013, 08:16 AM
Dyn0mitemat
Thread is 7/8-18 which works out to be super-fine thread, and usually custom tap size (my supplier had to custom grind mine)
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #17 of 35 Old 04-19-2013, 11:14 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
And you need to find a left hand tap in that size too.
They're super expensive.
Weld in bungs are really cheap.
ratmonkey is offline
post #18 of 35 Old 04-19-2013, 01:28 PM Thread Starter
riot1987
Originally Posted by KingtheZJ View Post
those weld in inserts are garbage. i have them and do not recommend them.
i would use a stock pitman arm with a high misalignment 1 ton TRE
isnt the thread specs listed on ruffstuff? i think they are 7/8" 28tip. i would run 1.5"OD .25 wall dom with the weld in tube adapters ruffstuff sells for that. check pricing on the dom first. it was cheaper for me to order the entire kit from ruffstuff, than buy the TREs from them and DOM local. they are 17$ flat rate shipping on DOM.
I priced some **** and its really about the same. I think ill get everything from RS.
Why dont you like those inserts? You think its better to ream out my knuckles? Those inserts weld in right?
Build thread^^
riot1987 is offline
post #19 of 35 Old 04-19-2013, 05:16 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the inserts don't like to stay welded in and they're not designed very well.
post #20 of 35 Old 04-19-2013, 06:40 PM Thread Starter
riot1987
Well damn.. Now I feel like I should Get a Reaming tool instead
Build thread^^
riot1987 is offline
post #21 of 35 Old 04-19-2013, 06:50 PM Thread Starter
riot1987
SO....
I just found this. Its a HANSON, R220 1/2-1 reaming? Tool Im thinking.
This is what Ill need correct? I found it in my dads shop. Its the only one he has. Is it Bueno?
Its 4.5" long
Build thread^^
riot1987 is offline
post #22 of 35 Old 04-19-2013, 07:00 PM Thread Starter
riot1987
Im not sure if this is hardened or not. It doesnt say. Its def not too sharp either.. Im sure thats not ideal but would it still work?
Build thread^^
riot1987 is offline
post #23 of 35 Old 04-20-2013, 10:29 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I've got the snap on one. I've done 8 knuckles, 3 pitman arms, and a pair of high steer arms and one drag link end for the inverted t steering.
post #24 of 35 Old 04-20-2013, 10:40 AM Thread Starter
riot1987
so you think that one I have will work? Is there any way to tell if its hardened?
I heard you can kinda tell by the color sparks it makes if ya grind on it a bit?
Build thread^^
riot1987 is offline
post #25 of 35 Old 04-20-2013, 11:54 AM
jeeepguy
jeeepguy's Avatar
If you go to the JCR website, they have links to several places to get the proper reamer.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #26 of 35 Old 04-20-2013, 12:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
It will work if it works. No telling what its been through before.
Knuckles and pitman arms are really soft metal.
post #27 of 35 Old 04-20-2013, 12:10 PM Thread Starter
riot1987
Im gonna try it, if it doesnt work then I havent lost anything. I dont want to buy one but those inserts dont sound too solid so Id rather do it right
Build thread^^
riot1987 is offline
post #28 of 35 Old 10-06-2013, 10:39 PM
jetjr91
Did you end up reaming the knuckles and pitman arm? I'm collecting parts for the wj knuckle swap too and am also thinking about the ruffstuff gm 1 ton steering. How did it go? Pretty easy to do?
jetjr91 is offline
post #29 of 35 Old 10-13-2013, 06:30 PM Thread Starter
riot1987
Im in the process still. Im 99.9% sure Im going with this linkage. I got my knuckles cleaned up and painted today
Build thread^^
riot1987 is offline
post #30 of 35 Old 10-13-2013, 06:42 PM
jetjr91
Oh alrighty
Did you blast the knuckles? Or wire wheels them? And what kind of paint did you use? I wire wheeled mine and they came out decent
jetjr91 is offline
