you know you drive a ZJ when... - Page 681 - JeepForum.com
 4Likes
post #10201 of 10778 Old 05-03-2014, 03:51 PM
smccloud
Originally Posted by davigzj View Post
@ smccloud
Your front Axel seals are from the inside of the pumpkin . You must remove your ring gear asembly to get to them..
Yeah, I know. But I have to take the axles out to pull out the diff in order to put in the seals.
smccloud is offline
post #10202 of 10778 Old 05-03-2014, 03:58 PM
davigzj
OK I just didn't want you to find out the Hard way..
davigzj is offline
post #10203 of 10778 Old 05-03-2014, 04:00 PM
smccloud
I'm less looking forward to doing the real axle seals in the wife's Explorer. And rebuilding the posi in my ZJ.....
smccloud is offline
post #10204 of 10778 Old 05-03-2014, 07:20 PM
Tigersan
...When passenger side floor is wet in the summer when you heavily use the AC
...When your whole car vibrates around 70MPH
...When every day you drive, there's a new noise...
1998 ZJ 5.9 Limited Platinum 100xxx miles...
Tigersan is offline
post #10205 of 10778 Old 05-03-2014, 08:37 PM
Scopez
1994 ZJ
When this is never a tiring sight.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #10206 of 10778 Old 05-03-2014, 11:33 PM
SchizophrenicMC
2016 JK Wrangler
When your front axle's pinion bearing bites it and you hate that you have to dump hundreds of dollars into a Dana 30 because you can't justify a Dana 44 swap.
Signature rules are dumb
SchizophrenicMC is offline
post #10207 of 10778 Old 05-04-2014, 06:27 PM
96_zj_laredo
When this is the most relevant thing you've seen all day
All I need in life is my Jeep, my guns, and my wrenches... And maybe some fine women too
96_zj_laredo is offline
post #10208 of 10778 Old 05-05-2014, 04:34 PM
cgcarpenter
Are the ac compressor brackets the same through all the years or does it change in 96-98
cgcarpenter is offline
post #10209 of 10778 Old 05-05-2014, 08:54 PM
davigzj
Jack's hiding by the ZJ (24)
davigzj is offline
post #10210 of 10778 Old 05-09-2014, 09:53 AM
Volklin
You know you drive a ZJ when it randomly decides to not start. All the lights, etc come on, but the engine just sits there staring at you like you're an idiot, and you have to put it in neutral while holding down the brake, throttle, and key to coax it into starting.
It's not very high on my list of things to fix, since I can always get it started and I'm more worried about fixing the bad ball joints, tie rod ends, bad shocks, and rotted control arm bushings.
Volklin is offline
post #10211 of 10778 Old 05-09-2014, 03:49 PM
Myusername1674
When you put the doors back on, and the windows won't roll up, and now whenever you try and roll the windows up, the alarms starts going off...
Oh how I wish for a Jeep without all the fancy 90's pos electronics...
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #10212 of 10778 Old 05-09-2014, 04:05 PM
Scopez
1994 ZJ
Originally Posted by Myusername1674
When you put the doors back on, and the windows won't roll up, and now whenever you try and roll the windows up, the alarms starts going off... Oh how I wish for a Jeep without all the fancy 90's pos electronics...
My doors are going on as I type this, let's hope I don't have this issue.
Scopez is offline
post #10213 of 10778 Old 05-09-2014, 04:26 PM
96_zj_laredo
You ever get pulled over for no doors?
post #10214 of 10778 Old 05-09-2014, 04:41 PM
big98tnzj
Mines been off for about 2 weeks and ive never had a problem with the cops. I think as long as youre not doing anything stupid then you should be fine
Sent from the mtns of TN using JeepForum
big98tnzj is offline
post #10215 of 10778 Old 05-09-2014, 04:54 PM
Scopez
1994 ZJ
Nope. Just calling for rain tomorrow and Sunday here so I rather be safe than sorry. Passed so many cops without doors. A couple starred, a couple waved, a couple didn't pay any attention but none cut their lights on.
Scopez is offline
