you know you drive a ZJ when... - Page 62 - JeepForum.com
 4Likes
post #916 of 10778 Old 03-10-2012, 01:24 PM
Lakoswolf
Originally Posted by Camaro16 View Post
Haha I love my VIC - 7,000 miles till next service? Well, if you insist...
HAHAHA exactly!
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #917 of 10778 Old 03-10-2012, 03:50 PM
nickpequignot
When something breaks/stops working and you know exactly what is wrong and how to fix it.
nickpequignot is offline
post #918 of 10778 Old 03-10-2012, 04:17 PM
TurboTPI
Haha. Yep
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #919 of 10778 Old 03-10-2012, 04:44 PM
Uniblurb
Uniblurb's Avatar
When all the cast/metal parts on the underside look like they've been on the ocean floor and you keep expecting to see barnacles growing on them. But when people look at the topside they say, "It looks like it's in really good condition!".
Uniblurb is offline
post #920 of 10778 Old 03-10-2012, 05:36 PM
ejschultz
Haha, we worked on todd4198's ZJ yesterday. I thought for sure the knuckles were covered an algae.
ejschultz is offline
post #921 of 10778 Old 03-10-2012, 06:08 PM
V65Ozzie
Originally Posted by 95_ZJ_Limited View Post
When you have to constantly reset your VIC after already replacing it once
Mine didn't work at all after I bought my Jeep, so I grabbed a JY unit, lo and behold it worked. 2 days later I got a coolant sensor warning, replaced sensor, no fix. Discovered common issue with sensor warning.
Broke transfer case, replaced transfer case. For a week no coolant sensor warning.....WTF?
Just went I started to get used to no warning. beep beep beep.......aaaaaaarrrrgggghhhhhh!!
V65Ozzie is offline
post #922 of 10778 Old 03-10-2012, 06:42 PM
DeansWings
This may be a duplicate, but when something starts working as it should and you assume that means something wrong. Mine shifted out of overdrive for once when I was trying to pass someone, and the first thing I did was check my ATF.
'96 ZJ 4.0 NP242 5.5" Iron Rock Off Road Critical Path Long Arm sitting on 33x12.5x15 Goodyear Duratracs
'06 WK 3.7 2wd stock as a rock.
The Build:
North Texas Grands:
Youtube wheeling vids (mostly from Bridgeport):
Grand Slam Texas!:
DeansWings is offline
post #923 of 10778 Old 03-11-2012, 07:57 AM Thread Starter
95_ZJ_Limited
yea, if my check engine light does not come on while driving I feel as of something is wrong
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #924 of 10778 Old 03-11-2012, 09:10 AM
CNTLOSE
I think the check engine light is actually the "All is Okay" light.
1996 Jeep Grand Cherokee...Rubicon Express 2" BB, RE Shocks, M/T Classic II w/ 30x9.5" Falken AT Tires
CNTLOSE is offline
post #925 of 10778 Old 03-11-2012, 09:26 AM
Tre3
When your in Mexico see another zj's and wonder what problems they have with theres
Tre3 is offline
post #926 of 10778 Old 03-11-2012, 09:44 AM
nickpequignot
Yeah my cousin was driving mine the other day. At wide open when it hit about 70 he looked and said I think I fu**** it up. I was like what's wrong, check engine light came on. I said its alright it's a jeep nothing's wrong with it
post #927 of 10778 Old 03-11-2012, 10:13 AM
Uniblurb
Uniblurb's Avatar
When you find a piece of black electrical tape blends right in when covering up the abs idiot light which always stares you in the face.
Finally replaced the left rear abs wheel speed sensor but the tape worked great for months on end.
Uniblurb is offline
post #928 of 10778 Old 03-11-2012, 10:42 AM Thread Starter
95_ZJ_Limited
when your headlight is being held at the desired angle by a zip tie
post #929 of 10778 Old 03-11-2012, 10:48 AM
squazz
......when you drop the rear upper control arm nut into the frame for the 2nd time after you say to yourself maybe I should put some electrical tape in the socket
squazz is offline
post #930 of 10778 Old 03-11-2012, 10:49 AM
squazz
I use a empty folded pack of smokes
squazz is offline
