you know you drive a ZJ when... - Page 598 - JeepForum.com
 2Likes
post #8956 of 10778 Old 10-28-2013, 02:29 PM
cgcarpenter
Originally Posted by SchizophrenicMC
I have all new sensors, that's the problem. TPS, CPS, CKS, UO2, DO2, IAT, MAP, CTS, and even the OPS and knock sensor for good measure. The only sensor still original is the speed sensor, because it's the only one I can prove is reading properly. I'm 4 PCMs into it, I've replaced everything related to the ignition except the distributor body, I flow-tested all the fuel injectors, and the engine has perfect compression to boot. The wires are all, as far as I can tell, intact because no amount of jostling them changed running conditions during the times it was running well. At this point, the only thing I haven't done is replace the catalytic converter. I did pop a couple of holes into the pipe fore of it and it didn't seem to do anything, not to mention the ZJ doesn't display symptoms of a failed cat (ie hesitation, stalling at high RPM, etc) but now the cat is clearly rattling so it's getting replaced. My O2 sensor code is Bank 1 Sensor 2 High Voltage. That is, it's reading higher than acceptable hydrocarbon emissions, which is suggestive of rich operation and/or impaired catalyst function. If it makes anyone feel better, I'll hit my ignition switch with my multimeter and post results. I don't believe I'm suffering from a shorting PCM or intermittent power loss, because it does store trouble codes. The original PCM did have damaged circuits and would randomly reset while driving, causing it to not store codes. You know you drive a ZJ when you've committed to sell it but you still have to do all these tests just to be sure.
My first PCM wouldn't read on an diagnostic tool. Second one would. But it was lazy. Lose spark. Lazy voltage regulator. And it always smelled like it was running rich.
Just bought my third one last Friday. And it's been great. Don't think I've ever felt it run as well now then when I bought it two years ago.
Not saying it is your PCM but never rule it out.
cgcarpenter is offline
post #8957 of 10778 Old 10-28-2013, 07:05 PM
somebody5788
1994 ZJ
It could still be reading wrong.... The 5.2 I referred to earlier was catless when I got it and still is but with good O2's it doesn't have that code. It was also throwing the front one off causing it to run rich because they were in the same circuit.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #8958 of 10778 Old 10-29-2013, 10:49 AM
V65Ozzie
Originally Posted by JeepNicholson View Post
Mine beat a Veyron in the quarter mile by like 5 seconds
Maybe, but the Veyron sucked the paint off it when it passed you at 200........
Imma gonna drive one of those, someday......
Retreat? Hell, we just got here......
V65Ozzie is offline
post #8959 of 10778 Old 10-29-2013, 12:06 PM
JeepNicholson
Veyron works better than aircraft stripper in that regard! Lol
JeepNicholson is offline
post #8960 of 10778 Old 10-29-2013, 01:12 PM
SchizophrenicMC
2016 JK Wrangler
So I cut my cat off, and this is what the inside looked like:
So it's DEFINITELY not a clogged cat, and all of the sensors and PCM are new. This also explains why the tattletale sensor was reading a malfunctioning catalyst. What now?
Signature rules are dumb
SchizophrenicMC is offline
post #8961 of 10778 Old 10-29-2013, 02:19 PM
V65Ozzie
Time to put an emulator in that thing..... magnumtuning.com
V65Ozzie is offline
post #8962 of 10778 Old 10-29-2013, 02:23 PM
SchizophrenicMC
2016 JK Wrangler
I think, since my money situation fell through just enough for me to not afford a JK, I might instead pursue finding a good V8 ZJ and swap all of my upgrade parts from Cheyenne over to that ZJ, including the 242, and return Cheyenne essentially to stock and recover some of my expense, while still keeping a ZJ. Sell Cheyenne for whatever I can get.
Any thoughts?
post #8963 of 10778 Old 10-29-2013, 02:34 PM
Concolour
1994 ZJ
When you see one for sale for two grand and you think "jeez, that's overpriced" then when you go to sell yours you post for fifteen hundred and get offended when people want to only pay 700
Concolour is offline
post #8964 of 10778 Old 10-29-2013, 03:05 PM
SchizophrenicMC
2016 JK Wrangler
I'd pay 2 grand for a good ZJ. I helped my buddy get a 97 Orvis for $2100.
But yeah, the harsh fact is, for all the money I've sunk into my ZJ, I won't get anything back out of it. Not like with TJs and JKs.
post #8965 of 10778 Old 10-29-2013, 03:15 PM
comptiger5000
Any thoughts?
Not a bad idea. Finding one that's fairly solid as a starting point should make keeping up with any issues much, much easier. Maybe it's niner time?
comptiger5000 is offline
post #8966 of 10778 Old 10-29-2013, 03:16 PM
comptiger5000
Well, anything with a Wrangler badge is worth at least a few thousand $ even if it's got rust holes in the tub, chunks of frame missing and a blown motor.
post #8967 of 10778 Old 10-29-2013, 04:18 PM
SchizophrenicMC
2016 JK Wrangler
It's always Niner Time. The tough part is finding a niner local for a reasonable price. I'm not gonna be able to buy anything until January, but I don't wanna blow all my cash into another Jeep all at once.
Of course my other aversion to a niner is they didn't sell them in green in the US, and I think Moss Green Pearl is the best color for a ZJ.
post #8968 of 10778 Old 10-29-2013, 04:46 PM
smccloud
It's always Niner Time. The tough part is finding a niner local for a reasonable price. I'm not gonna be able to buy anything until January, but I don't wanna blow all my cash into another Jeep all at once. Of course my other aversion to a niner is they didn't sell them in green in the US, and I think Moss Green Pearl is the best color for a ZJ.
I've seen a Niner I would walk away from if someone offered to pay me to take it. The body was so bad I'm guessing the drivetrain wasn't worth the time to pull out to swap into mine
smccloud is offline
post #8969 of 10778 Old 10-29-2013, 07:17 PM
rebelbowtie
I feel the same way about XJ's (even though I paid $2500) but I always look on Craigslist and think none of them are worth more than $500-1,000
rebelbowtie is offline
post #8970 of 10778 Old 10-30-2013, 12:33 AM
Myusername1674
When you see a dumb jk parked at school and have to make a meme, 'cause we all know that pavement pounder never leaves the street poser
And when your bored you make this too. I really need to sleep...
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
