you know you drive a ZJ when... - Page 566 - JeepForum.com
 4Likes
post #8476 of 10778 Old 09-07-2013, 02:08 PM
MustangFX93
When you drive with the radio off because either
A: You love how your jeep sounds
or
B: You're listening for something to go wrong
MustangFX93 is offline
post #8477 of 10778 Old 09-07-2013, 02:11 PM
Scopez
1994 ZJ
or
On my Road Trip yesterday, I had the radio down. I just had a feeling something might break, it was the road...
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #8478 of 10778 Old 09-07-2013, 03:39 PM
AnotherRedZj
Originally Posted by comptiger5000 View Post
160 is honestly too cold for a modern engine. There's no reason to run it that cold in the first place, and second, it'll get a bit worse gas mileage and wear the cylinder walls faster due to them being colder.
What's the reason for wanting a 160 in the first place?
Probly shoulda mentioned it was for work, pulling a trailer all day every day up and down the coast.
Originally Posted by dnuccio View Post
trying to get this damn thing to run cooler. helped a little, but its still hotter than id like it (around 220). only cooling system component i havent replaced yet is the fan clutch, gonna pick one up later today. if that doesnt do it, i dont know what will. its got a brand new 3 row all metal radiator, trans cooler bypassed into a large auxiliary cooler, new water pump, new rad cap (18lb), new hoses, and now a new thermostat. the 180 i had in it was only 2000 miles old.
Clutch probly shoulda been the first thing replaced!
AnotherRedZj is offline
post #8479 of 10778 Old 09-07-2013, 09:11 PM
Texsun
when you can recline your seats and take a nap because it's so comfortable!
Texsun is offline
post #8480 of 10778 Old 09-07-2013, 09:26 PM
Maine1994ZJ
or
A! (glad it's not just me....)
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #8481 of 10778 Old 09-07-2013, 10:37 PM
dnuccio
Cooler t-stat won't fix that. If it's running 20* hotter than t-stat temp, the t-stat is already wide open, so something else is limiting its ability to stay cool. Bad fan clutch could definitely do it, so I'd replace that and see what happens.
replaced the clutch, still runs hot. got up to 230 on the freeway. i dont know what the **** else it could be. and check engine light came on, code 32, egr system malfunction. could that have something to do with it?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8482 of 10778 Old 09-08-2013, 04:42 AM
roughknight69
You did replace the water pump right? What about completely flushing the old system. That was my problem.
Build thread
roughknight69 is offline
post #8483 of 10778 Old 09-08-2013, 07:33 AM
dnuccio
in February, i replaced most of the cooling system. i put in a new radiator (single row chinese POS that killed my motor), new water pump, new 180* t stat, new stant rad cap, and new hoses. ever since then, it has always ran a little hotter than i want it.
funny thing is, before i did all that, it never ran hot. at all. the only reason i did all that was because the radiator had a very small leak at the bottom.
the temp never got above 210, even when i towed a 6000lb trailer in 95* desert heat.
i know it was running hot because of the single row rad, didnt have the cooling capacity. thats what killed my motor. after i rebuilt the top end, i put in this CSF 3 row, all metal. its the most heavy duty rad i could find.
R.I.P. Ratmonkey
dnuccio is offline
post #8484 of 10778 Old 09-08-2013, 07:39 AM
comptiger5000
Have you taken an IR temp gun to the t-stat housing to confirm that the gauge is accurate? It's possible that it's reading hotter than it really is.
comptiger5000 is offline
post #8485 of 10778 Old 09-08-2013, 12:04 PM
dnuccio
yes i have, both readings are within 2-3 degrees of each other
R.I.P. Ratmonkey
dnuccio is offline
post #8486 of 10778 Old 09-08-2013, 01:27 PM
Scopez
1994 ZJ
My 96 has a standard fan clutch, the one on my dads 97 has a heavy duty one. It's constantly sounding like a jet engine when you nail the gas.
The 97 does run cooler than my 96. Both 5.2s
Scopez is offline
post #8487 of 10778 Old 09-08-2013, 02:04 PM
roughknight69
Build thread
post #8488 of 10778 Old 09-08-2013, 06:30 PM
dnuccio
heres an idea
sometime right before i messed with the cooling system, i did the 703 injector swap. now according to zander21510's injector swap thread, the 703 injector flows 21.5lb/hr at 39psi. the stock 1995 5.2 injector flows 24.6lb/hr at 39psi. so im thinking that because the 703s flow less fuel, its running the engine leaner, thus causing my hot running condition. am i on the right track here?
R.I.P. Ratmonkey
dnuccio is offline
post #8489 of 10778 Old 09-08-2013, 07:14 PM
Scopez
1994 ZJ
heres an idea
Try your old injectors and see. Could be extremely possibly. Has your MPG changed any? If that fixes your problem, ill buy them injectors from ya.
Scopez is offline
post #8490 of 10778 Old 09-08-2013, 08:29 PM
dnuccio
yeah im gonna put my old injectors back in and see. Gotta wait til next weekend though because I lost one of the old injectors and the only yard that has any 95s wont let you in unless your 18, so I have to go with my dad
R.I.P. Ratmonkey
dnuccio is offline
