you know you drive a ZJ when... - Page 565 - JeepForum.com
 2Likes
post #8461 of 10778 Old 09-06-2013, 08:37 PM
Scopez
1994 ZJ
When your driving on the interstate, see a Honda civic come flying by in the fast lane, decide to catch up to him and ride beside him and see if you can get him to speed up and just nail it and watch his facial expression from 70-100.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #8462 of 10778 Old 09-06-2013, 08:39 PM
rebelbowtie
Originally Posted by AnotherRedZj
Easily hundreds of jk's in my area (military base) but the only one I ever seen on the trails is my cousin when he goes with me. Other then that I only see yj's, cj's and xj's out there.
Send the XJ's my way, I could use a few more fixed roof Jeeps in my club!
rebelbowtie is offline
post #8463 of 10778 Old 09-06-2013, 09:51 PM
dnuccio
i swear these ZJs just KNOW. looking at XJs the last few days for my buddy, and i started thinking how I wouldnt mind having one too, then today the ZJ overheats on me.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8464 of 10778 Old 09-06-2013, 09:59 PM
Scopez
1994 ZJ
How bad?
Scopez is offline
post #8465 of 10778 Old 09-06-2013, 10:42 PM
dnuccio
Originally Posted by Scopez View Post
How bad?
bad enough that the overflow couldnt keep up and it was spraying coolant out the rad cap. dont think it hurt the motor though.
replacing the thermostat (has a 180 in it, im putting in a 160) and radiator cap tomorrow, as well as installing an aftermarket water temp gauge, because im fairly certain the factory one isnt accurate. if the tstat and rad cap dont fix it, the only other cooling system component i havent replaced yet is the fan clutch (mucho dinero $$$ bleh)
R.I.P. Ratmonkey
dnuccio is offline
post #8466 of 10778 Old 09-06-2013, 10:49 PM
Scopez
1994 ZJ
160? Winter is nearing though. Granted your in AZ right? I'm putting a mopar tstat in, along with an Efan. I dislike my fan clutch.
Scopez is offline
post #8467 of 10778 Old 09-07-2013, 02:34 AM
CGlaser
I have a 160 in mine. Duting the winter as well. Its ok. If you dont mind it tsking over half your trip before it starts putting heat out
http://www.jeepforum.com/forum/f22/98-zj-slow-build-1484672/
CGlaser is offline
post #8468 of 10778 Old 09-07-2013, 07:58 AM
dnuccio
yep, im in Phoenix. doesnt get too cold here, and right now its hot as hell, so hopefully the 160 will help for the time being. if i have a problem with it when winter comes, ill throw the 180 back in.
R.I.P. Ratmonkey
dnuccio is offline
post #8469 of 10778 Old 09-07-2013, 01:43 PM
AnotherRedZj
160 works great in my 1500. But like said before takes awhile to kick heat. Not so bad on the FL coast though!
AnotherRedZj is offline
post #8470 of 10778 Old 09-07-2013, 01:45 PM
comptiger5000
160 is honestly too cold for a modern engine. There's no reason to run it that cold in the first place, and second, it'll get a bit worse gas mileage and wear the cylinder walls faster due to them being colder.
What's the reason for wanting a 160 in the first place?
comptiger5000 is offline
post #8471 of 10778 Old 09-07-2013, 01:47 PM
Martin600
Then I run out of gears, and he creeps past...
Don't know what Civics are like in the US, but they're pretty nippy in UK spec. my 4.0 would have no chance against an EK9
We don't have niners here in the UK either only 5.2
Martin600 is offline
post #8472 of 10778 Old 09-07-2013, 01:49 PM
dnuccio
trying to get this damn thing to run cooler. helped a little, but its still hotter than id like it (around 220). only cooling system component i havent replaced yet is the fan clutch, gonna pick one up later today. if that doesnt do it, i dont know what will. its got a brand new 3 row all metal radiator, trans cooler bypassed into a large auxiliary cooler, new water pump, new rad cap (18lb), new hoses, and now a new thermostat. the 180 i had in it was only 2000 miles old.
R.I.P. Ratmonkey
dnuccio is offline
post #8473 of 10778 Old 09-07-2013, 01:50 PM
Scopez
1994 ZJ
I've put just about any Civic here in its place. Especially these high school kids with the bumble bee exhaust. My 5.2 in my 96 has alot more get up and go than my 5.2 in my dads 97...I dunno.
Scopez is offline
post #8474 of 10778 Old 09-07-2013, 01:54 PM
comptiger5000
Cooler t-stat won't fix that. If it's running 20* hotter than t-stat temp, the t-stat is already wide open, so something else is limiting its ability to stay cool. Bad fan clutch could definitely do it, so I'd replace that and see what happens.
post #8475 of 10778 Old 09-07-2013, 02:05 PM
Scopez
1994 ZJ
Any air in the system? My ZJ ran around 215-220ish until I burped it. Now it's around 205.
Scopez is offline
