you know you drive a ZJ when... - Page 534 - JeepForum.com
 2Likes
post #7996 of 10778 Old 07-06-2013, 08:40 PM
SchizophrenicMC
2016 JK Wrangler
You know you drive a ZJ when XJ owners are on your case for knowing your Jeep is simply better than their Jeep.
Also, when
makes you laugh.
Signature rules are dumb
SchizophrenicMC is offline
post #7997 of 10778 Old 07-06-2013, 08:45 PM
dnuccio
Also, when this makes you laugh.
show me the carfax!
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7998 of 10778 Old 07-06-2013, 08:47 PM
jeepmojo
1992 XJ Cherokee
Originally Posted by Afdude88 View Post
When the driver window is open and you run the wipers to get the water off and the forward part of the door gets soaked
Dana 35c behind a 242, behind an AW-4, behind a 4.0L Inline Six sitting over a Dana 30, all turning stock 215/75/15 tires and moving a 93 Grand Cherokee to places your truck only dreams of.
Did this in a mud hole! Now my door panels have mud spots all over them!!
Money doesn't buy happiness, but it buys a Jeep. And I ain't ever seen a sad person in a Jeep!!
jeepmojo is offline
post #7999 of 10778 Old 07-06-2013, 09:23 PM
xcaliber81
I wonder why the check engine light was on.
xcaliber81 is online now
post #8000 of 10778 Old 07-06-2013, 09:51 PM
9859limited
Originally Posted by Scopez View Post
Everyone doesn't believe that ZJs (5.2s) can beat most vehicles off the line. I've beat an eclipse GT...don't ride my *** then flip me off. I let em see nothing but tail lights.
Haha all the Time. All the time. So on topic when you throw a new transfer case in after blowing the old one into two pieces and she's been running better than ever.....
9859limited is offline
post #8001 of 10778 Old 07-07-2013, 12:30 AM
jeepmojo
1992 XJ Cherokee
When you pull out the drive in your Father in Laws Hemi Magnum and as you look in the rear view your ZJ is flipping you off!!
jeepmojo is offline
post #8002 of 10778 Old 07-07-2013, 07:26 AM
comptiger5000
The WK2 certainly does not handle worse than the ZJ. ZJs may have more suspension travel, but the damn beam axle weighs so much and is guided by a primitive 5-link suspension with a recirculating-ball steering system, it can't comprehend handling at all. Too much suspension float, too little steering feedback. I got to drive a WK2 a couple months ago, the thing not only rode nicer, but had more steering feedback and more controlled roll, as well as increased grip. It's no nimble sports car, but to say it handles worse than the ZJ because it's heavier is false. The suspension design accounts for the heavier weight far better than the ZJ's beam axles
The WK2 does do a much better job of feeling like it handles well. It might be more responsive, but it's certainly not better in terms of outright grip (on smooth pavement, the solid axles lose grip fast in the rough stuff) or ability to get through a slalom, etc. quickly.
Let's look at some numbers:
The ZJ came with 225s under it for tires, usually in the form of Goodyear Wranglers, which were pretty sucky for grip.
The WK2 comes with 265s under it in the form of Michelin Latitude Tours, which are definitely better tires.
Yet despite all that extra tire under the WK2, they pull an identical 0.74g on a skidpad (WJ: 0.76g stock, WK: 0.72g stock). An early Motortrend test of a 93 ZJ pulled 0.75g out of it.
In a slalom, the WK2 is about 1 mph faster according to the fastest test I've found (although I've seen a couple that tested a little slower than a ZJ), most likely due to the testers pushing it right up to the stability control. However, that could easily be changed by adding a little more caster to the ZJ (30 second adjustment, adds more front end grip).
Also, despite its puny brakes, the ZJ does 60-0 faster than the WK2 (126 ft vs 131 ft).
The WK2 is definitely more aerodynamic though.
comptiger5000 is offline
post #8003 of 10778 Old 07-07-2013, 10:40 AM
Scopez
1994 ZJ
Everytime I drive the 13 Ram 5.7, my ZJ flips me off.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #8004 of 10778 Old 07-07-2013, 10:59 AM
4LBlackMamba
dude...all the time...especially when it rains and I'm making a right turn...soo much water ha
4LBlackMamba is offline
post #8005 of 10778 Old 07-07-2013, 11:08 AM
4LBlackMamba
Also, when Video Link: http://www.youtube.com/watch?v=i7Umdyq6pBY&feature=share makes you laugh.
they don't die!! I just gained so much more respect for my ZJ lol...
post #8006 of 10778 Old 07-07-2013, 04:12 PM
Area11
You know you drive a ZJ when you put rocks in the motor and it still runs.
Area11 is offline
post #8007 of 10778 Old 07-07-2013, 06:43 PM
4LBlackMamba
atleast I know if I need to do an emergency oil change (if there even is such a thing..) me and my buddies can just piss in the darn thing and I'm good to go
post #8008 of 10778 Old 07-07-2013, 11:20 PM
Concolour
1994 ZJ
When the first thing you check on any zj you park next to is how far the rocker panel rust is progressing
Concolour is offline
post #8009 of 10778 Old 07-08-2013, 06:53 AM
ZjNightmare
When the junkyard knows you by name
When the junkyard tells you where the "new" zj is
When you break or damage the same part so many times the junkyard runs out
Mud in the wheels, slippin transmisson, aint got much but I treat it like gold
ZjNightmare is offline
post #8010 of 10778 Old 07-08-2013, 08:08 PM
Scopez
1994 ZJ
Had a guy come in where I work...had a XJ on 33s. I was telling him how I was lifting my ZJ in a month or so....he says "don't get a body lift, they tip over too easy now." I responded...if you would've bought your XJ and would've built it, you'd gladly know you cant put body lifts on a unibody frame! Then he was telling me how quick his 300 straight 6 is...I raced it this night in my 01 ram 1500 5.9L (it's built on 35s)...put him to shame. He couldn't handle a V8 even in a ZJ. I'm starting to think he didn't even have a 300 straight 6...
Scopez is offline
