you know you drive a ZJ when... - Page 49 - JeepForum.com
 4Likes
post #721 of 10778 Old 02-28-2012, 10:16 PM
tjtenor4
Originally Posted by Cameleer View Post
I love the sky hooks on my ZJ, added them a few months ago and already had a chance to use them.
As far as I know you can only install sky hooks on a ZJ because it has a unibody and is very well balanced.
Only with a ZJ Got to love them!
Wow, My ZJ was really dirty back then!
This is a freaking cool picture... but, where are your drive shafts??
tjtenor4 is offline
post #722 of 10778 Old 02-28-2012, 10:59 PM
Cameleer
Originally Posted by badbird17x View Post
On my trail rig I mounted a 12v pump that circulates my blinker fluid to my muffler bearings, then to an after cooler in the front. I run 5.9 fluid, with the cooler, unbelievable how well it all works.
I would highly recommend also getting a muffler bearing gauge for your ZJ.
My left muffler bearing just went out and if I wouldn't have caught it quickly I could have really screwed something up!
I don't know why the ZJ's didn't come stock with one!
Get one before it's too late It saved my rear!
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #723 of 10778 Old 02-28-2012, 11:10 PM
Scopez
1994 ZJ
Mines broke.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #724 of 10778 Old 02-28-2012, 11:14 PM
Tankmeister
You should also be sure to get the compressor for the 9ers blinker fluid, since they use a much more dense fluid it is sometimes difficult for the 9er's to transport the fluids quick enough, but the compressor will add that little extra and make sure it gains some extra power and smoothness for the blinker fluid, (common fix for the 9ers Blinker Fluid Low issue)
1996 ZJ "Tank" - 5.2 Deceased =(
1993 ZJ "Halftrack" - 4.0 with 4" Rough Country Lift and 31x10.50xR15 General Grabber AT^2's, Custom Limb Risers, Bumper Lights, Rubicon Express Double Shear Track-Bar, Rancho Steering Stabilizer, Crown HD steering setup, Black Widow roof basket.
Tankmeister is offline
post #725 of 10778 Old 02-28-2012, 11:25 PM
Cameleer
Originally Posted by samsonitesamson View Post
I was just thinking how clean it was!
That was dirty, this is clean! Although I have cleaned it up some more.
You know you drive a ZJ 5.9 when you spend too much time cleaning it.
I kind of enjoy laying under my ZJ and keeping her clean. Maybe I should seek a little
I still have a 249 TC and could burn out the VC when using sky hooks if I didn't remove the drive shafts. Also the muffle bearings where removed just to be safe.
Cameleer is offline
post #726 of 10778 Old 02-29-2012, 05:27 AM
1stblack97ZJ
idk if it's just the angle, but your camber looks pretty bad there.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #727 of 10778 Old 02-29-2012, 05:28 AM
1stblack97ZJ
it's a photoshopped pic
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #728 of 10778 Old 02-29-2012, 06:08 AM Thread Starter
95_ZJ_Limited
How often should you change your carburetor belts??
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #729 of 10778 Old 02-29-2012, 08:07 AM
ejschultz
Every 12k miles. I do mine when I rotate my lug nuts.
ejschultz is offline
post #730 of 10778 Old 02-29-2012, 08:30 AM
jmonty0523
I got the self rotating lug nuts on my ZJ... less maintenance ...
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #731 of 10778 Old 02-29-2012, 08:39 AM Thread Starter
95_ZJ_Limited
Ugh, I forgot about that. I usually
use an X pattern.
post #732 of 10778 Old 02-29-2012, 10:00 AM
badbird17x
badbird17x's Avatar
1994 ZJ
I've never owned a zj with a carburetor belt, but I did install a new double roller throttle body chain. Love it as it never slips.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #733 of 10778 Old 02-29-2012, 11:13 AM
pincheburro956
I have the same setup. Did u have to remove the throttle body tensioner to get enough clearence.
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #734 of 10778 Old 02-29-2012, 11:32 AM
zander21510
I installed a carburated antifreeze compressor for my water-cooled o2 sensors. Straight up bolt on for my power differential circulatory pump.
zander21510 is offline
post #735 of 10778 Old 02-29-2012, 11:40 AM
Dluenz
To help with the double roller throttle body chain I added some hydraulic chain tensors, they work great! I never have any slack. I did have to remove the pull starter though to get everything to fit right. But I think its worth it!
Dluenz is offline
