you know you drive a ZJ when... - Page 45 - JeepForum.com
 4Likes
post #661 of 10778 Old 02-26-2012, 06:55 PM
ejschultz
ejschultz's Avatar
My Caprice runs 17s. I'll take any of ya!
ejschultz is offline
post #662 of 10778 Old 02-26-2012, 07:04 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Originally Posted by vegasZJ
Whats you ta run? Would love to race it with my mustang. But thats a different tread.
Best it ran was 10.70 with old engine and a 150 shot. Sold it and parted out the 9 sec engine before it hit the strip but new engine made 628 na and was set up for 150 shot off the line, then another 150 after 1-2 shift. This in a 2800lb car with 28/10.5 slicks and 4.56 with a fully set up suspention, you do the math. Found a buyer and decided I wanted to build a 2500hp Nelson lsx twin turbo rail car. Then life changed so.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #663 of 10778 Old 02-26-2012, 07:06 PM
vegasZJ
My zj on 33s runs in the 16s
When in doubt throttle out!
vegasZJ is offline
post #664 of 10778 Old 02-26-2012, 07:12 PM
vegasZJ
Let me know when its done. I have a 93 fox twin 88mm turbos 408in stroker. 28" tire runs ok haven't had a clean pass.
vegasZJ is offline
post #665 of 10778 Old 02-26-2012, 07:16 PM
vegasZJ
93 fox twin 88mm turbos 408in stroker. Runs ok haven't had a clean pass
vegasZJ is offline
post #666 of 10778 Old 02-26-2012, 07:39 PM
TurboTPI
Twin 88's!? Mother of god! I wish my mid10 sec firebird had one 88. Haha. Maybe it'd crack a single digit pass.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #667 of 10778 Old 02-26-2012, 07:39 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Won't be done. Car is cruising the street right now with 435 Hp no spray. Sold the car as a street car. Sold the engine in pieces. Not building the rail as I had a life changing experience and spend my time crawling trails with friends instead of getting a slip.
Point of all of this is if you want a cheap trail rig buy a zj, if you want a cheap yet very nice street and trail rig, by a niner. I might add cameleer is the king in this category. Otherwise, especially if there is a unlimited budget like some of you have brought up, there are way way better platforms to start with. Like say a Hemi wk, or srt8, at least it would be worth something when it's done. Niners are awesome, most likely will be for a long time. But they are a unibody with an old *** engine with old *** technology, weak steering, weak axles fnr, crappy off-road case, and not the greatest transmission. All vehicles have problems but if I had a unlimited budget a 14 year old vehicle would be the last place I started.
post #668 of 10778 Old 02-26-2012, 07:45 PM
vegasZJ
Agreed the zj is like a handy man jack of all trades but master of none
vegasZJ is offline
post #669 of 10778 Old 02-26-2012, 08:11 PM
vegasZJ
I wash my mustang would run a single digit pass. Ran mid 10s popping and spitting on the big end.
vegasZJ is offline
post #670 of 10778 Old 02-26-2012, 08:20 PM
ejschultz
ejschultz's Avatar
Damn. Guess you got me. 4.3L V8 ftl.
post #671 of 10778 Old 02-26-2012, 08:21 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Getting it out of the hole is the hard part with that kind of power. What's it running out of? Sounds like a fuel issue. Mine had 2 in-tank, with a booster for the spray. I would have needed more for the race engine. This is why I boned it out. Had all the suspension but needed a $3000 trans, a $2000 rear, $3000 cage, $1000 fuel system, and a big *** diet. All to drop 2 seconds. That's why I figured $5000 for a used chromoly roller, about $30,000 for a Nelson engine, I'd have a little more in it but could lift at the 1/8 and easily run a 9 once I sorted out getting that monster out of the hole.
post #672 of 10778 Old 02-26-2012, 08:30 PM
jeepgoonie
2008 XK Commander
You know you drive a zj when youre so proud of it, you think it can go up against anything
Just Empty Every Pocket
jeepgoonie is offline
post #673 of 10778 Old 02-26-2012, 08:37 PM
jtackerman28
When you steering has so much play then you drive a low mile car and have to relearn to drive.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #674 of 10778 Old 02-26-2012, 08:50 PM Thread Starter
95_ZJ_Limited
When you've outrun ricer civics and VW's
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #675 of 10778 Old 02-26-2012, 09:49 PM
ME_Blackpaw
When your garage is starting to look like a loading dock.......littered with boxes from different parts suppliers and a member from this forum!!
ME_Blackpaw is offline
