you know you drive a ZJ when... - Page 410 - JeepForum.com
 1Likes
post #6136 of 10763 Old 03-14-2013, 10:52 PM
xrunndonex
1994 ZJ
Originally Posted by dnuccio View Post
some day i want to put a 5.9 in a comanche and build the hell out of the motor and have a scary fast 2wd street/strip truck
Have it be a sleeper to haha
xrunndonex is offline
post #6137 of 10763 Old 03-14-2013, 10:59 PM
dnuccio
thats the plan
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6138 of 10763 Old 03-14-2013, 11:09 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
A Comanche would be crazy with that much power. I bought my first wife an '87 2wd sport w/2.5 4cyl and that truck is so light I could roast the tires and drift corners.
D3<!L!>3D
S8NNG8 is offline
post #6139 of 10763 Old 03-14-2013, 11:47 PM
SchizophrenicMC
Originally Posted by nickpequignot View Post
How does it reduce your options? Exact same block as a 5.2 only difference is that the 5.9 is externally balanced vs the 5.2 internal balance. Other than that its the same thing. How would the limit your options? I'd say it opens up a whole new can of worms and get have quite a bit of power with not a ton of work, and NA vs what you will get out of a boosted 4.0 which probably won't be much more than a stock 5.9. Yeah a boosted 4.0 would be sweet. But it's just not my motor of choice if I want any power.
First off, let it be known that the 5.2 is way too big for the ZJ as it is. The amount of **** I had to cut to get the V8 out of the donor is ridiculous. This lack of space means there's nowhere to practically put a supercharger, or really much of anything into that engine bay. Your only options are to go NA. Maybe you could get a remote turbo in there. The stock niner makes 245hp from the factory, on 93 octane. You can push this to 300 with some effort. The 4.0 makes 185hp on 87 octane, but I figure with some doing, I could get it to 300 on 93, just the same, but with some creativity instead of an additional 2 liters of displacement.
With the 4.0, you can stroke, port, super, or turbo, and still have room in the bay. That leftover space means a damn lot when you're actually working on stuff. Plus you can't have a sleeper with a 5.9, especially if you run forced induction on it. You'd have to cut the hood open for the blower. Subtlety is important to me as well.
The 4.0 leaves you more options as a Jeeper, and has pretty much the same level of options for actually building the motor than the V8s available, meaning you do have more options for it.
All I wanna know now is how am I gonna make a 42RE hold the kind of power I want?
1997 Grand Cherokee Orvis Edition
FUEL ECONOMY IS FOR LOSERS
SchizophrenicMC is offline
post #6140 of 10763 Old 03-15-2013, 12:34 AM
comptiger5000
Fitting a blower on a 5.2/5.9 is certainly doable, it's been done quite a few times before (centrifugal blower, or the Kenne Bell roots blower sitting next to the engine and ducted, although that one required cutting the cowl for clearance). The 4.0 does have tons more room in the engine bay though, working on certain things on the 5.9 is a royal PITA, and certain mods require getting creative with placement of stuff.
The 4.0 is a bit more expensive to build for higher power though, and the parts options are more limited. It can certainly be done though.
For the trans, talk to Martin Saine. He's the guru of the 40 series torqueflites.
Originally Posted by Scopez View Post
I love that. I was in my ram 1500 5.9L (sitting on 35s) and this dodge neon srt4 decided to test me...we were at the red light side by side. I violently did alittle power braking, just enough to hold the tires from spinning. Light turned green, bye bye 4cylinder. I was doing every bit of 85mph in a 45mph zone...true duals were screaming, redlined in first and second.
I'm guessing the guy couldn't drive for ****, as an SRT4 should definitely be faster than that truck.
comptiger5000 is offline
post #6141 of 10763 Old 03-15-2013, 05:43 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
I can think if at least 15 guys off hand with supercharged 5.9s. A lot of them have kept stock hoods. There's at least one twin turbo in the works. You just have to get creative.
If you took that creativity you want to use on the 4.0 and applied it to a V8, you'd get some pretty impressive results. No replacement for displacement haha.
And Martin will get you anything you need as far as transmissions go.
Sent from my iPhone 6 using JeepForum
In the garage: M1 4bbl
McCloudsZJ is offline
post #6142 of 10763 Old 03-15-2013, 05:47 AM
nickpequignot
I was gonna say go tell the guys on the speed freaks they can't supercharge a 5.2 or 5.9. Battery has to be relocated to the back which is better for weight distribution anyways. And the fuse box under the hood is rotated so its parallel with the fender. And then your golden on space for a blower
nickpequignot is offline
post #6143 of 10763 Old 03-15-2013, 06:16 AM
Concolour
1994 ZJ
Gguuuuuuuuyyyyyyssssss stop giving me ideas on how to spend my money lol!!!
You know you drive one when...
Concolour is offline
post #6144 of 10763 Old 03-15-2013, 06:45 AM
noodles5124
Ot: when reading this thread makes you spend more money than you have lol
noodles5124 is offline
post #6145 of 10763 Old 03-15-2013, 06:59 AM
comptiger5000
I'm pretty sure a couple people have been able to keep the battery up front by moving the PDC and spinning the battery sideways.
post #6146 of 10763 Old 03-15-2013, 07:23 AM
Scopez
1994 ZJ
If you had to cut **** to pull a V8 out of a ZJ, you're doing something wrong. I just pulled my 5.2L without any problems.
There's no way in hell a SRT4 is faster than my truck that's built. 4.88 gears, Plenum has been fixed, intake has the kegger mod, A/C delete to free up a few horses, hi-flow exhaust, performance PCM.
I've beat plenty of cars in my truck and ZJs. Mustangs V8s and V6s, Firebirds V8s and V6s, a couple beamers, among a few other cars.
I live, eat, and sleep magnum motors. I know just about everything about them and how to build them, internally and externally.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #6147 of 10763 Old 03-15-2013, 07:34 AM
Concolour
1994 ZJ
Well you didn't say your truck wasn't stock now did you
post #6148 of 10763 Old 03-15-2013, 07:53 AM
comptiger5000
Didn't know it had anything else done to it. SRT4 was definitely stock though, considering I'd guess that truck ran mid 14s at best? An SRT4 will run a 13.9 stock with a good driver and good tires. Keep in mind, my ZJ, which is definitely lighter than a RAM 1500, won't run better than high 14s with 3.73s, 29.5" tires, upgraded heads, mild cam, tune, exhaust redone from the manifolds back.
post #6149 of 10763 Old 03-15-2013, 08:56 AM
JohnCrabtree
1994 ZJ
Says it all
JohnCrabtree is offline
post #6150 of 10763 Old 03-15-2013, 09:46 AM
Scopez
1994 ZJ
I'd guess my truck would run around low 14s or high 13s.
SRT4 had alittle bumble bee exhaust and who knows what else. He kept up with me off the line, but once I got to second gear, he was looking at my tail lights. Also, I have procomp mud terrains with American Racing wheels.
Scopez is offline
