YOU DECIDE I WILL FOLLOW Please help!!! - Page 2 - JeepForum.com
post #16 of 27 Old 08-06-2009, 07:21 AM Thread Starter
xxmarcoxx
Thanks fellows!!!
I knew the main problem was the kick down cable, or should i say what started this whole mess!!!
the cable is 50 bucks but the shop wants to charge me 200 total to replace it, but if he rebuilds the tranny everything is included in one price, thats why i havent "fix" that yet cause i figure it will be cheaper if just did it that way.
If i fix the cable, change the solenoids to fix the code P1757 and P1762 Flush trans, New Filter Maybe the car can last me the mechanic said, and tht will cost me about 500-600 to do. or he said i can pay him 2k and have him rebuild the whole thing and fix and install.. i know is 1500 more.. but what if i change it all, 3 weeks later goes bad and now i have to spend an extra 2k plus the 500 600 i already spent!!
so hard to find a trustworthy mechanic!
xxmarcoxx is offline
post #17 of 27 Old 08-06-2009, 08:50 AM
PTCHBLKZJ
what year is ur jeep man i probalby should have asked that before
PTCHBLKZJ is offline
post #18 of 27 Old 08-06-2009, 06:43 PM Thread Starter
xxmarcoxx
is a 2004 jeep grand cherokee limited edition, with 75k miles.. thank everyone anyone else who has any idea is welcome to help.
post #19 of 27 Old 08-06-2009, 07:02 PM
PTCHBLKZJ
oh ok thats y ur tranny went haywire cause its all electronic mines a 95 and its not all electronic when mine was doing it shifted super fast then going into overdrive it would like go into nuetral before it went into overdrive so it would rpm up then slam into over drive lol man automatic trannys are weird i wish i had a 5 speed lol
post #20 of 27 Old 08-06-2009, 07:17 PM
ZeeJay1997
You can get a kickdown cable for about 30 bucks. get the P/n from a dealer or maybe someone here has it. then go to ebay and buy one.
My tranny has a little metal in the pan everytime I take it off. Go by the assumption your mechanic was trying to get your money.
Try the cable first . Then all you have if the tranny drops later is a new cable you needed to begin with.
ZeeJay1997 is offline
post #21 of 27 Old 08-06-2009, 07:37 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you really have to make sure the cable is adjusted within 1/8" of being dead nuts on.
though other sensors can cause similar issues, having the kick down cable not modulating the pressure is causing your shifting issues and your trouble codes.
ratmonkey is offline
post #22 of 27 Old 08-07-2009, 08:55 AM Thread Starter
xxmarcoxx
So i went to a different "shop" today. and they told me they can:
Replace cable
Replace solenoid and governors for errors P1757 and P1762
Flush the trans and put a new one..
For 650.00 what do u guys think??
He also said that if problem comes back within 90 days he can put the 650.00 towards the 1600 Rebuild..
Thanks again and any new coments are always welcome!
post #23 of 27 Old 08-07-2009, 09:06 AM
rugermack
Why not try the cable first, clear codes and see what happens.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #24 of 27 Old 08-07-2009, 09:19 AM Thread Starter
xxmarcoxx
yeah i guess i can do that, i just figured if the P1757 and P1762 codes came thru, and is such a common problem.. those probably need to changed?? just a guess..
post #25 of 27 Old 08-07-2009, 10:06 AM
PTCHBLKZJ
yeah dude it sound like he's trying to work with u just be carefull cause there are people out there
post #26 of 27 Old 08-07-2009, 06:22 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the kick down cable modulates line pressure, the sensors tell the computer what the line pressure is. if the sensors are bad they'll throw those codes, if the kick down cable is not adjusted correctly or is missing it'll throw the same codes.
post #27 of 27 Old 08-07-2009, 06:40 PM
WhiteOut
WhiteOut's Avatar
Anyone trying to give you a "new" tranny for $650 is gonna screw you in the end. Kickdown is easy to do with a few tools, its detailed in the Haynes manual.
WhiteOut is offline
WG/WJ Snorkels nearly available WH/WK to follow shortly johnv WK Grand Cherokee & XK Commander Forum 0 07-15-2009 03:30 AM
New Parts on the Way...Full Writeups to Follow ('07 Commander) JohnnyBighead WK Grand Cherokee & XK Commander Forum 7 07-19-2007 02:00 PM
Follow-up on previous tranny shifting troubles... stabmaster ZJ Grand Cherokee Forum 13 03-06-2006 04:55 PM
Oil Seal Follow Up Question: for my95jgc matt.x ZJ Grand Cherokee Forum 3 01-25-2005 11:01 PM
fog light follow up f14x4 ZJ Grand Cherokee Forum 0 06-09-2003 09:55 PM
