Yoke for Front diff help - JeepForum.com
post #1 of 17 Old 03-30-2014, 07:44 PM Thread Starter
sharpie54
I have a 1995 zj orvis edition. Need to know what front yoke I need to convert my cv front driveshaft to ujoint. Need a new front yoke and I don't know what to get that will be the same spline. And is my front diff a Dana 35? Thanks
sharpie54 is offline
post #2 of 17 Old 03-30-2014, 09:11 PM
90Notch306
Front axle is a dana 30. Pretty sure all d30 yokes are the same spline. Dont quote me though
90Notch306 is offline
post #3 of 17 Old 03-31-2014, 10:30 AM
mrgimble
2015 JK Wrangler
Dana 44 yokes fit as well from CJ, TJ, XJ, ZJ.
I used this one.
http://www.4wheelparts.com/Drivetrai...D3044-YOKE-UBK
mrgimble is offline
post #4 of 17 Old 03-31-2014, 12:02 PM Thread Starter
sharpie54
Alright sweet thanks. So pretty much any front yoke from a cherokee in the same year should work weather they are 2wd 4wd or awd?
post #5 of 17 Old 03-31-2014, 12:31 PM
PolkaPower
2wd won't have a front yoke. Any XJ or ZJ will use a D30 in the front with the same yoke. They are all interchangeable. In mid to late 95+ they started using a CV front drive shaft on the V8's or any I6 with a 249. You won't be able to use those. It needs to be a u jointed drive shaft and yoke. It's easy enough to take a look and know instantly.
PolkaPower is offline
post #6 of 17 Old 03-31-2014, 12:41 PM Thread Starter
sharpie54
Yea I meant to say 2wd/4wd. But yea as long as it has a front Dana 30 and a ujoint styler I should be good to swap it?
post #7 of 17 Old 03-31-2014, 12:52 PM
PolkaPower
Yes. Except for the high pinion D30's you may find in the XJ's, those are reverse cut so I'm not sure if it will work or not but I don't see why the yoke would be different.
post #8 of 17 Old 03-31-2014, 09:56 PM Thread Starter
sharpie54
Ah alright I see. What size driveshaft should I look for? Mines around 36'-37' right now...plan on lifting another 3 inches so what kind if jeep should I take one out of?
post #9 of 17 Old 04-01-2014, 08:04 AM
PolkaPower
Earlier zj's have longer shafts. You will have to measure.
post #10 of 17 Old 04-01-2014, 12:02 PM
JohnnyZJ
and D30 yoke will work.
the ONLY driveshaft you will find that works comes out of a 93-95 ZJ V8 LAREDO model. best of luck finding one. in theory, you could use any double cardan driveshaft off a jeep as all the ujoints would be the same, but nothing else out there is long enough.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #11 of 17 Old 04-01-2014, 12:53 PM
takethisride
If youre looking for a new one, I used Omix-Ada 16580.07 when I converted to U joint to CV on my 96 5.2 w/ Dana 30... Runs about $45, you will probabaly save a little if you hit the Junk Yard up.
96 ZJ 5.2L 4x4, 4.5" Lift, NP231 swap, Beefed Custom Cline front DS, 33" Goodyear Wrangler Duratracs, 15x10 RCX wheels, JKS front and Rear track-bars, Flowmaster 40series, Cobra CB radio, Optima Yellow Top, Snorkel, Rough Country winch mount, Super Winch TS9500, cut fenders, Red Jeep Club #572, Built Not Bought #279
takethisride is offline
post #12 of 17 Old 04-01-2014, 02:45 PM Thread Starter
sharpie54
What is this Omix Ada driveshaft? Where can I find it?
post #13 of 17 Old 04-03-2014, 12:17 AM
shaban
I've just used a driveshaft from an older 'ZJ that came with a 242 case, they used u-jointed front shafts.
Mine is 4.0 though.
Keep in mind that you'd also need to re-set the front diff pinion bearing preload if you replace the yoke.
You'd need at least new yoke nut, 250 ft-lbs torque wrench and 10 in-lbs beam type torque wrench.
Plus new crush sleeve and pinion seal if you want to do it by the book.
shaban is offline
post #14 of 17 Old 04-03-2014, 12:01 PM Thread Starter
sharpie54
I'm having my mechanic guy do it so I'll mention all that. I don't want to mess anything up with my front diff
post #15 of 17 Old 04-03-2014, 12:26 PM
PolkaPower
A lot of mechanics do it the cheap and easy way by reusing the old crush sleeve and tightening it a little more than it was and call it a day. Just for your FYI. You may not ever have a problem with that and if you do it will be long enough down the road to where you can't blame them.
