Quantcast Yeah, another lift thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Yeah, another lift thread
Old 04-10-2008, 10:53 AM   #1
98ZJ_USMC
While I am fairly well versed in most mechanical repair, I am a lift newbie. I want to put a very modest 2" spring lift on my 98ZJ. With 236k of easy highway on it, the springs are worn hence, a spring replacement lift would be best. I have read about the driveshaft (front) vibration problems with 3.5" and above lifts but, has anyone experienced this with the more modest 2-2.5"? I just re-tired with 245-75x16 up from the stock 225's and the ride is great for the moderate trail and (very) moderate mudding I do. I don't forsee a bigger set of meats going on.
Thanks!
98 ZJ 5.2 Auto with "one [COLOR="DarkOrange"][SIZE="5"]million[/SIZE][/COLOR]" miles on it. Camoclad exterior means you never have to wax it! The journey continues......Jeep On, baby!
98ZJ_USMC is offline   Reply With Quote
Old 04-10-2008, 11:06 AM   #2
QuadraTokn
1930 WJ
You wont get ANY vibes at that height unless something else is worn out. I think OME makes 2" lift springs.
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 04-10-2008, 11:25 AM   #3
98ZJ_USMC
Thanks, tokn. Post-lift, I am going to start looking at all the rubber bushings and replacing with poly as I go.
Old 04-10-2008, 11:45 AM   #4
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Poly bushings - a great way to add road noise and harshness to your ride. The OEM bushings lasted 200k for you the first go around, they'll be fine for the next 100k the Jeep has left in it.
ArloGuthroJeep is offline   Reply With Quote
Old 04-10-2008, 12:00 PM   #5
pieter314
A possibly related question would be if replacing all bushings is a reasonably sensible thing to do while you're in there installing a lift. Seems so to me, but I'm new to this as well. I'd be using regular factory rubber. I've got enough other vehicles built to loosen my fillings, my wife and I don't need this one to do the same!
pieter314 is offline   Reply With Quote
Old 04-10-2008, 04:14 PM   #6
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The factory rubber bushings are great.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 04-10-2008, 05:39 PM   #7
tirus89
Why are poly bushings so bad?
Im a student and unemployed and have a Haynes.
//93 ZJ//5.2L//NP249//K&N Fipk Gen II//2" BB w/BD AT Shocks//4.10's//31" Cooper Discovery STT's//Cstm Frnt Bmpr//Custom Rear Tube Bmpr//3" Magnaflow exhaust w/high flow cat//500RMS Pioneer Amp//600RMS 12" JL Audio Sub//4 Hella 500's on Cstm Light Bar//Sealed Intake Box w/ ram air//
tirus89 is offline   Reply With Quote
Old 04-10-2008, 06:09 PM   #8
ArloGuthroJeep
Mr. Hyde!
They aren't bad, but because they are stiffer they transmit more road noise/harshness to the vehicle.
Old 04-10-2008, 06:50 PM   #9
tirus89
That makes sense, I just read about them in Offroad and 4x4 mags. What is a good factory replacement then?
Old 04-10-2008, 07:10 PM   #10
ArloGuthroJeep
Mr. Hyde!
Any rubber aftermarket bushing...they'll most likely outlast your Jeep...
Old 04-10-2008, 08:37 PM   #11
tirus89
Any brands that you have come across in your looking that stood out in performace, and should I get mine replaced when doing my lift
Old 04-10-2008, 09:31 PM   #12
ArloGuthroJeep
Mr. Hyde!
Moog is a well known replacement.
Old 04-10-2008, 10:30 PM   #13
98ZJ_USMC
Hmmmm. I didn't realize that. Much harsher, eh? I must rethink this. I imagine the factory rubber ones will be a tad cheaper, too. Thanks, Arlo! I probably read one too many brochures some years ago when I was going to redo an 85' Toyota I had since birth.
Old 04-11-2008, 08:15 AM   #14
LaCeS OuT
1994 ZJ
You will be fine with poly. They arent that much of a difference. I have poly rear sway bar bushings and sway end links in the rear and it rides fine. Its a jeep not a caddy. I also have poly control arm bushings on the lowers front and rear.
Jeep Sold! 02/2009
Need AMSOIL? Click Here!
LaCeS OuT is offline   Reply With Quote
Glock Forum
