03-25-2009, 07:29 AM
#1
Is this a direct swap? will all the steering components mount up and will the CA brackets line up, I'm upgrading to full adjustables. is it the same width?
-1993 Grand Cherokee Laredo V8 5.2, Mopar CAI, Borla headers, Borla Y-pipe, Turn down exhaust, 4" RC SA, 33x12.50r15 BfGoodrich Km2, Crown extended brake lines, IRO Double Shear Track bar, IRO HD tie rod, Home made Quick discos, E-fan, Heavy duty harness/9007 bulb conversion, HP30 WJ knuckles lockrite solid cover.
BUILD THREAD: http://www.jeepforum.com/forum/f197/...-jeep-1133312/
03-25-2009, 10:10 AM
#2
Living dead mod
almost direct. driveshafts will be different lengths and mounting for the sway bar endlinks may be a little different.
#3
Consider the following...
Grab the driveshaft off the XJ as well and you should be good.
Put your bacon where your mouth is!
03-25-2009, 10:15 AM
#4
Sounds good. I'm asking cause I chewed up my ring and pinion in my d30 on my ZJ and it sat for over a month cause I'm joblesss and couldn't afford to fix it so I decided to throw the hubs rotors and calipers on with no axles or diff. in-erds and well to say the least I learned when you fix something fix it right. I went down the road about 50 feet and the hub snapped and my tire is hanging on by the brake line and it looks like I bent the knuckle, and since I'll be speding a whole lota money I'm gonna just swap in an hp30 and throw a ox locker in while I'm at it.
03-25-2009, 10:21 AM
#5
the unit bearing needs the axle outer shaft at a minumum to stay together. If you had put the outers back in it would have been fine.
03-25-2009, 10:22 AM
#6
the outers? what do you mean if I threw the shafts in there I might've gotten away with it?
03-25-2009, 10:49 AM
#7
Living dead mod
from the ujoint or cv joint out it must be in the hub to keep it together.
03-25-2009, 10:58 AM
#8
You may also have problems with caster adjustment. The LP D30 has the adjustment on the axle, the HP D30 has it on the "frame." If you put in the HP D30, you have no OEM adjustment.
There are a few solutions. Adjustable LCAs of course, or get the caster adjustment buckets and shims off the frame of the donor XJ, and then elongate the holes on your ZJ LCA mount to get adjustment. You can see the factory almost went this route, as they put in the holes to mount the adjuster buckets!
If you have any lift, you may not even need a new drive shaft.
03-25-2009, 12:28 PM
#9
Lucky bastards with your 3.55 gears. There's about 10 XJs sitting in my junkyard, and front axles are $95, but you know how rare a newer XJ with ABS and 3.73's is?
'98 ZJ Laredo 5.2L Selec-Trac ~ Rock crawler on the outside, luxo-cruiser on the inside
3.5" IRO lift // 31" Cooper STT's // D44a Aussie Locker // NP242 swap // KOR Tow Shackles
'08 Kawasaki Ninja 250R ~ Daily Driver, 50 mpg Speed Demon
#27. Shirts get dirty. Underwear gets dirty. Pants? Pants never get dirty, and you can wear them forever.
03-25-2009, 01:56 PM
#10
Location: Vancouver, British Columbia, British Columbia
Is there info on the HP30 regarding the gears or do you have to count rotations?
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
03-25-2009, 01:58 PM
#11
check for a tag, that's the easiest way.
03-26-2009, 07:22 AM
#12
All I have is 2", but when i get back from boot I wanna try and go 3.5-4", do you think that's enough?
03-26-2009, 07:39 AM
#13
most or the time on the edge of the ring gear you can find two numbers telling you the tooth count
ie. 41 10 = 4.10 ratio
03-26-2009, 09:10 AM
#14
Will I need just adjustable lowers to gain my caster adjustment back?
03-26-2009, 10:12 AM
#15
If you find an early XJ like the 84-86 with a 2.8 V6 Auto, it may have 3.73s. I have 2 3.55 HP's sittin in my yard, just gotta throw one in.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 4" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers www.nsw4x4.com
