Xj front lower control arms on a zj? - JeepForum.com
post #1 of 3 Old 12-08-2010, 07:15 PM Thread Starter
bigupjail
So I've read a few places with people putting wj control arms for the curve and boxing on a xj and zj. I also read that xj control arms are 3/4 of an inch longer. So if wj fits on both, couldn't they swap too? I read also that the caster is adjusted at the end connecting to the body rather than by the axle but couldn't you just swap them in and use the cam bolts from the zj in the factory location? I am wondering cause I think I need longer arms since I lifted to 3.5-4 inches. I was thinking this would help out my caster that's at about 5. I know I can buy control arms but I'm broke and I got a deal on the jeep, I rather not drop alot into it.
Thanks for any input.
bigupjail is offline
post #2 of 3 Old 12-08-2010, 11:09 PM
ZJ5point2GCL
Not sure about length but they will bolt up, the xj's use an alignment shoe, but in your case it would still use the eccentric washer/ cam bolt/
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #3 of 3 Old 12-08-2010, 11:45 PM Thread Starter
bigupjail
Anyone know if the wj rear lowers work in the front of a zj? That would deft add some length.
front lower control arms dscommins ZJ Grand Cherokee Forum 10 03-16-2010 10:04 PM
shorten lower front control arms sdowney717 ZJ Grand Cherokee Forum 58 03-04-2010 03:06 PM
zj front and rear lower control arms the same? besthaticouldo ZJ Grand Cherokee Forum 2 06-02-2009 08:30 PM
Front lower control arms bolt Mike Cooper ZJ Grand Cherokee Forum 16 10-31-2008 04:30 PM
