WTF! i just changed spark plugs and now it idles really rough - JeepForum.com
post #1 of 16 Old 05-30-2009, 10:26 PM Thread Starter
MEinSoCal
it was running fine before, no CEL. i just decided to change my plugs due to high mileage. i tried 2 different brands of copper -- champion and bosch, and both had the same results. yes the plugs were properly gapped according to FSM and all bolts torqued to factory spec.
what the hell is happening here? it starts up like **** and idles very rough
MEinSoCal is offline
post #2 of 16 Old 05-30-2009, 10:38 PM
gatorayde
Maybe you bumped a sensor or the coil rail became damaged.
gatorayde is offline
post #3 of 16 Old 05-30-2009, 10:45 PM
ZeeJay1997
I'm going to list the things I can think of just in case you had a brain f*rt.
1. You crossed a plug wire
2. You broke a plug wire
3. A plug wires isn't seated good and arcing off the head. (look for blue spark at night)
4. You put the wrong plugs in it.
5. You cracked a plug
6. You cracked the distributor
7. You distributor cap is not seated properly
8. Your distributor is loose and you changed the timing (long shot)
Yikes, Does a 99 I6 have a rail???
Duh, bolts... of course it does dummy. Nevermind about the wires...
ZeeJay1997 is offline
post #4 of 16 Old 05-30-2009, 10:46 PM
gatorayde
No wires or distributors on WJ's
post #5 of 16 Old 05-30-2009, 10:48 PM Thread Starter
MEinSoCal
yes i have a coil rail. i really wish it was a simpler distributor and spark plug wire setup
post #6 of 16 Old 05-30-2009, 10:53 PM
ZeeJay1997
Disregard the babble, I live in another era.
post #7 of 16 Old 05-30-2009, 10:59 PM
Virmagicus
Virmagicus's Avatar
ZeeJay1997
Jeff
Virmagicus is offline
post #8 of 16 Old 05-30-2009, 11:06 PM
elmer_fud
try disconnecting the battery for a while (30+ minutes) and see if it resets the computer and helps it run better
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #9 of 16 Old 05-30-2009, 11:14 PM
the88thpianoman
2003 WJ
The coil rail is very sensitive. I hope that's not it, though.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #10 of 16 Old 05-30-2009, 11:41 PM Thread Starter
MEinSoCal
me too. i did kind of twist the wiring of the coil rail to move it out of the way. hopefully i didn't mess anything up
post #11 of 16 Old 05-31-2009, 12:37 AM
Envygreen
Go drive it for 5 minutes the computer will re-learn, If your gap was well worn its still using the old parameters
2004 WJ 4.0 limited "I'LL TAKE A COLD INTERIOR OVER CLADDING" Still have heated seats! 2008 Ranger, 2003 Powerstroke lariat straight pipe tuned, 2000 TJ Sport, leaky stak 3 speed and bunch of other stuff that i don't care to add up.
Envygreen is offline
post #12 of 16 Old 05-31-2009, 09:44 AM
4jeepers
I second the motion!
4jeepers is offline
post #13 of 16 Old 05-31-2009, 11:54 AM Thread Starter
MEinSoCal
UPDATE: so last night, after i changed to the 2nd set of spark plugs, i also cleaned out the throttle body and added 1/2 can of combustion cleaner. after going for a test drive, i got the CEL light to come on w/ 3 codes
0505 - IAC : i changed it with a new part from autozone (thank god they're open til midnite)
0123 - TPS : Throttle position sensor input above the maximum acceptable voltage
0108 - MAP : sensor input above maximum acceptable voltage.
i disconnected the battery to clear out the codes to see what would come back on. after replacing the IAC, the rough idle seemed like it was smoothed out. in fact the instructions said to drive the car with the engine warmed up, going 40mph to let the IAC adapt. did that and the its still running really rough, kind of like the engine is sputtering. can't even accelerate smoothly.
i'm almost tempted to replace the TPS next since my jeep is approaching 200K (and the part is only $45) and i'm sure the previous part is pretty damn old and has been used for a while. i'd hate to keep throwing parts if not needed.
on a side note, how do i troubleshoot a vacuum leak? where should i look? anyone have a pic of all the vacuum lines for a WJ 4.0L?
by the way, the CEL have not come back on... not yet at least
post #14 of 16 Old 05-31-2009, 06:34 PM
wj03grandy
2003 WJ
man im have the exact same problem for sometime now and i cant figure it out.
i replace the IAC, and the TPS (code) and i get a code for small vaccum leak (code) that i CAN NOT FIND!
wj03grandy is offline
post #15 of 16 Old 05-31-2009, 06:45 PM
Houndmaster1
You can look for a vac leak with a can of carb cleaner, spray around the intake, any gasket on the intake ant t-body. If the engine rpm changes you can isolate and find it. If you prefer, propane works to. I prefer carb cleaner. Idealy you can smoke it, if you have a smoke machine. A party smoker with a rubber hose will work with a little rigging.
Houndmaster1 is offline
4.0 idles rough when cold snowmon ZJ Grand Cherokee Forum 0 01-23-2010 01:25 AM
Aloha! 95 zj hardstarts and rough idles. HELP jeeponthebeach ZJ Grand Cherokee Forum 5 11-20-2009 01:29 PM
93 4.0 idles rough after warm mpgumby ZJ Grand Cherokee Forum 3 05-20-2009 09:23 PM
HELP !!changed spark plugs- Loud clicking from engine, then stalls alecmcmahon ZJ Grand Cherokee Forum 1 10-12-2008 03:06 PM
Just changed spark plugs....now gas mileage WORSE! Help. natef26 ZJ Grand Cherokee Forum 13 01-16-2006 08:08 AM
