WTF!!! Everything was fine.. THEN - JeepForum.com
post #1 of 17 Old 09-12-2012, 08:36 PM Thread Starter
MarsZJ
Jeep running decent, i go get some gas and come home to add a small clock to the spot my VIC was. So im done with the job and i start her up and now the piston slap or what ever is 5 times louder and i think its the start of a knock and the motor i running like *** and missing bad, like it loping up and down, then its fine then its bad, it drives fine and has all the same power but the piston slap is hideous when starting it up and it jeep is running rough as hell, sounds like crap. I'M so pissed of an angry. What is the deal!!! Sure the sound gets less when it warmed up but its whack when it first starts. This SUCKS! Nothing was done other than adding a clock. Yesterday i cleaned the throttle body and had to used blue RTV on the IAC body but after it cured it ran better than ever. Ran mint all day today to put 70 miles in her.
Then like i say, i came home parked it, put that clock in then ate dinner had a beer then this BS.. UGH!
1995 JZ 4.0 185K
MarsZJ is offline
post #2 of 17 Old 09-12-2012, 09:03 PM
96zedjay
Bad Gas?
96zedjay is offline
post #3 of 17 Old 09-12-2012, 10:13 PM
errorcode3
so are you saying that it was knocking prior to this whole incident? And then it suddenly got louder/worse after you filled up?
Yeah bad gas may cause problems, but if you had issues prior it was just a matter of time before it gets worse.
98 - Slate 5.niner. minor mods
02 - Silver Liberty (wives mall crawler)
errorcode3 is offline
post #4 of 17 Old 09-12-2012, 10:25 PM Thread Starter
MarsZJ
It was more like piston slap and it gets less when it warms up, I don't know
Its crazy
MarsZJ is offline
post #5 of 17 Old 09-13-2012, 01:00 AM Thread Starter
MarsZJ
One thing I should also add is since the new water pump and hoses, tstat and tstat housing the temp rarely guests above 1/4 of the way up since its been in the 50's at night here.
MarsZJ is offline
post #6 of 17 Old 09-13-2012, 01:03 AM Thread Starter
MarsZJ
Heat works fine and oil pressure is 22 at idle and 40+ when driving
MarsZJ is offline
post #7 of 17 Old 09-13-2012, 04:43 AM
ZeeJay1997
Knee jerk recommendation - Fuel treatment and 190* thermostat... installed correctly.
If it is actually piston slap you are hearing, nothing you can do without tearing into the engine.
ZeeJay1997 is offline
post #8 of 17 Old 09-13-2012, 06:54 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You have a bad thermostat.
You also, "didn't have problems then suddenly, bam."
Piston slap is a problem, and will just all of a sudden go boom! Stop driving it and rebuild the motor before it throws a rod or scores the cylinder too badly.
ratmonkey is offline
post #9 of 17 Old 09-13-2012, 10:20 AM Thread Starter
MarsZJ
Due to severe back injury a motor rebuild is out of the question. But one thing using a stethoscope I can say the sound comes from below the head but above the crank, its from I think the #3 or #4 piston its self so that bad. But it also is not 100% constant, for every 10 times it skips one, it gets less under load and goes almost silent after a long drive.
MarsZJ is offline
post #10 of 17 Old 09-13-2012, 03:04 PM Thread Starter
MarsZJ
dupe post / sorry
MarsZJ is offline
post #11 of 17 Old 09-13-2012, 03:06 PM Thread Starter
MarsZJ
MarsZJ is offline
post #12 of 17 Old 09-13-2012, 03:11 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
sounds more like rod knock.
and your thermostat is either stuck open or your temp sender is bad.
post #13 of 17 Old 09-13-2012, 03:47 PM Thread Starter
MarsZJ
The sound is much worse on the drivers side its like 70% more
MarsZJ is offline
post #14 of 17 Old 09-14-2012, 10:41 AM Thread Starter
MarsZJ
Anyone else?
MarsZJ is offline
post #15 of 17 Old 09-14-2012, 06:16 PM
ZeeJay1997
Anyone else?
If you mean does anyone else think you'll ruin it if you keep driving it, yes i think so.
Warranty Fine Print diver110 WK Grand Cherokee & XK Commander Forum 5 03-14-2012 11:32 AM
97 zj slips between 1st and 2nd but when im in 4th and it kicks down to 3rd its fine? aforce ZJ Grand Cherokee Forum 3 03-04-2012 08:43 PM
Sounds like bad CV Joints, but they are fine. Shadowless127 ZJ Grand Cherokee Forum 0 12-24-2011 01:51 PM
help, cant fine thread/links xj 98/yj 94 ZJ Grand Cherokee Forum 2 10-22-2007 07:45 PM
Ok fine, call me gay.... SteelBlue_WJ ZJ Grand Cherokee Forum 45 05-20-2006 01:42 PM
