WTB ECM for 1993 Jeep Grand Cherokee Limited - JeepForum.com
post #1 of 16 Old 12-05-2008, 07:09 AM Thread Starter
eprissel
I am pretty sure my ECM in my 1993 Grand Cherokee Limited 4.0 Auto is going out. I pulled the number from on top of it which is 56028116 and am wondering if anyone would have one lying around or know where I could get a decent deal on one??? I might know where one of them is but is would be out of a 1993 Laredo with a 4.0 5spd, would this work?
Thanks,
Eric
eprissel is offline
post #2 of 16 Old 12-05-2008, 09:54 AM Thread Starter
eprissel
Does anyone know where I can look to see what other ECMs would work?
eprissel is offline
post #3 of 16 Old 12-05-2008, 02:24 PM
elmer_fud
no idea where to check for compatible units. You could maybe pic one up from a junk yard
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #4 of 16 Old 12-05-2008, 03:59 PM
gomes512
1994 ZJ
What are the symptoms? What are condition of capacitors on the board? If caps, then ez fix.
gomes512 is offline
post #5 of 16 Old 12-05-2008, 06:08 PM
moparrr07
what is an ecm? the only thing you could be talking about is a pcm!
10 seconds on google
http://www.autopart.com/ecc/ECC1993J...NDCHEROKEE.htm
http://www.enginecontrolunits.com/ca...ROKEE/1993.htm
http://www.chryslerecu.net/partindex/ecuoem122.htm
why do you think it is going bad, usually they fail or they dont, again like he said, what are the syptoms?
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #6 of 16 Old 12-08-2008, 09:48 AM Thread Starter
eprissel
for some reason when I turn the key on the fuel pump is not kicking in, I have already changed relays and have ran the fuel pump manually from a switch to rule that out. it takes me about 5 minutes to start it in the morning and that is just sitting there and cycling the key until I hear the relays kick in and the fuel pump starts up...maybe I am way off I dont know?
eprissel is offline
post #7 of 16 Old 12-08-2008, 10:42 AM Thread Starter
eprissel
I also have heard that it could be my security system???
eprissel is offline
post #8 of 16 Old 12-08-2008, 12:48 PM
elmer_fud
doubt it. The security system lets you start, then it kills the engine after 5 seconds.
I would search for a broken wire or loose connection really carefully before replacing the ECM
Brian
post #9 of 16 Old 12-08-2008, 01:28 PM Thread Starter
eprissel
it will start but only after I mess around with it for several minutes. it just cranks over. I thought the security system disables it so it will just crank over?
eprissel is offline
post #10 of 16 Old 12-08-2008, 07:59 PM
vp6799
I had to replace the ecm on my 96. Not sure if the same thing applies to older OBD1 zj's as with the OBD2 zj's, but the only thing I had to watch out for is the factory security. I went to the dealer and got my build sheet. Checked it and I didn't have factory security. Then went to the parts yard and wrote down the vin to every 6cyl laredo zj they had and went back to the dealer to get build sheets for those. Just picked the first one that didn't have the factory security and it worked flawless.
vp6799 is offline
post #11 of 16 Old 12-09-2008, 02:26 PM Thread Starter
eprissel
Nice, well I already disabled my security system last night by grounding out the purple/yellow wire in the kick panel and its still the same so that rules that out. I guess I am on the hunt for a junkyard ecm...
eprissel is offline
post #12 of 16 Old 12-09-2008, 11:05 PM
vp6799
The tech I spoke with said it doesn't work that way. If the ecm has factory security, the new one will have to have it also. The BCM will not function correctly if the wrong ecm is installed. If you don't have factory security and you get an ecm with it, he said the bcm and a few other things will short out because of miscomunication between the 2.
I would def try to get one with security, less chance of screwing up other stuff.
vp6799 is offline
post #13 of 16 Old 12-10-2008, 12:02 AM
Kolak
Vendor
Kolak's Avatar
There's no BCM in the 1993 ZJ -- the body control module was not utilized until 1996.
I'd have to poke around in the service manual, but the fact that the fuel pump relay does not engage is not necessarily indicative of a bad relay. Yes, the PCM/ECM/PCU/ECU (whatever you want to call it, LOL) has to energize the relay. But this is based on it getting the correct input from various sensors, etc. In other words, it may be on the input side to the PCM rather than the output side. It could be something as simple as the ignition switch.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #14 of 16 Old 12-10-2008, 09:12 AM Thread Starter
eprissel
I am gonna try to get a service manual from a dealer and start testing, it shouldnt be this hard...
eprissel is offline
post #15 of 16 Old 12-22-2008, 11:36 AM Thread Starter
eprissel
had to replace the ecm...found one from the exact year and model jeep I have and the guy gave it to me for free because the sticker was missing and he couldnt verify the numbers...20 bucks shipping thats it and it started no problem at -25 degrees this morning.
1993 Jeep Grand Cherokee Limited 4.0L - Stock
2004 Dodge SRT4 - FOR SALE
Cold Air Intake
Mopar BOV
eprissel is offline
1993 Grand Cherokee Limited Vibrates Daddygrogg ZJ Grand Cherokee Forum 18 11-25-2009 04:05 PM
1993 Grand Cherokee Limited ECM needed! eprissel ZJ Grand Cherokee Forum 5 11-22-2008 09:54 PM
1993 Jeep Grand Cherokee Limited 5.2 serdartimur ZJ Grand Cherokee Forum 0 07-30-2008 07:22 AM
1993 Grand Cherokee limited for $1900 (look) JucinGTA ZJ Grand Cherokee Forum 5 01-07-2002 07:59 PM
1993 jeep grand cherokee limited lee8431 ZJ Grand Cherokee Forum 2 12-10-2001 02:25 AM
