Writeup on d35c to d44a swap - Page 2 - JeepForum.com
post #16 of 34 Old 06-22-2011, 08:22 PM
biggoofy
i swapped in a complete 44a into my zj and used my stock d35 shaft and am only on 2" of lift its a direct swap.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #17 of 34 Old 06-22-2011, 09:23 PM
AlphaLorde
^^^^^^ POST A PIC @ THE TCASE & DS^^^^^^^^^
You can bolt the stock turdy5 ds in but it will be tight. I drove for 24 hrs with the stock one, it had less then an 1/8" of room between the tcase seal end of the slip yoke. Need 1-1.5" or so.
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #18 of 34 Old 01-17-2012, 10:07 AM
biggoofy
Im no longer on that setup. I never had a single issue using the stock d35 shaft.
Zack
13 JKU Stock
biggoofy is offline
post #19 of 34 Old 01-17-2012, 10:27 AM
PolkaPower
Just do the swap and measure. A shop won't charge much to make it the correct length and they will balance it too. Maybe 60 bucks give or take.
PolkaPower is online now
post #20 of 34 Old 02-01-2012, 06:37 AM
Newb1995jeepgc
1994 ZJ
Another question.. On a 95 V8 ZJ, if i get the D44a off of a 96 will my drive shaft work or will i need the drive shaft off of the 96
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #21 of 34 Old 02-01-2012, 08:08 AM
speedbucket
The pinion is one inch longer than the 35.
It depends on the length of the transmission and how much lift you have
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #22 of 34 Old 02-08-2012, 07:10 AM
Newb1995jeepgc
1994 ZJ
i have no lift and i have the 46RH Tranny.
post #23 of 34 Old 02-08-2012, 07:48 AM
speedbucket
Then you will need to have you're. Driveshaft shortened because the 46rh is the longest tranny if I remember correctly=shortest rear driveshaft.
post #24 of 34 Old 03-11-2012, 11:58 PM
pincheburro956
great write up and comments. thanks everyone... was thinking about this or an 8.8. seems this is easier....
one question: what is IIRC.
Still cant figure it out.
laughing at self:
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #25 of 34 Old 03-12-2012, 05:17 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Going from a 35 to a 35 and all this info helps alot. Being really green on this stuff I have debated on doing this myself. Still on the fence but none of the stuff is rusted so maybe it will come loose easy.
coralman is offline
post #26 of 34 Old 03-12-2012, 07:09 AM Thread Starter
KingtheZJ
if i remember correctly
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #27 of 34 Old 03-12-2012, 08:18 AM
pincheburro956
Ahhhh, Thank you much...
post #28 of 34 Old 05-24-2013, 08:47 PM
tucsonzj
ok not trying to revive a dead thread, but easy access is to put this in my list.
JY has a d44 with 3.73's (matching what I have now) and am considering picking it up.
And if I'm reading this correct, with the 46RE tranny, at slightly over 3" of lift, I wouldn't (more than likely) need to get my rear drive shaft shortened...?
BTW one i'm looking at is a D44 with the hex cover.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #29 of 34 Old 12-30-2015, 11:05 AM
technophat
I know this thread is old, but the info is still good. I picked up a Dana 44a for $125 last night, and I'll be using the OP's info to guide me. I have a stock '94 GC with a bad ring gear in a Dana 35. My GC has drum brakes and the D44a has disk. The only three areas I'm expecting problems is with the brake conversion, the U-joint, and having the drive shaft shortened and balanced to fit the new length.
I'll post up the results of my experience in a separate thread.
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #30 of 34 Old 12-30-2015, 05:17 PM
kg6mov
Hears the voices
kg6mov's Avatar
This thread has some misinformation in it, but is mostly correct.
Unless the d44a is from a niner the u-joint is the same. Only the niner got 1330 u joints.
kg6mov is online now
D44A Aussie Locker installed - Writeup, opinions, and pictures MSU.WJ ZJ Grand Cherokee Forum 27 11-23-2012 07:23 PM
D44a swap 98ZJDan ZJ Grand Cherokee Forum 4 08-14-2010 08:32 PM
Swap D35 with D44a WhiteOut ZJ Grand Cherokee Forum 16 03-10-2010 10:34 PM
D35c swapped to D44a grandpapy ZJ Grand Cherokee Forum 8 05-09-2008 11:41 AM
D44a Wheel Bearings the same as d35c? Jgw50 ZJ Grand Cherokee Forum 1 08-18-2005 02:50 PM
