Write-Up on Washer Fluid Pump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Write-Up on Washer Fluid Pump
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 08-23-2010, 02:33 PM   #1
dropped74
Per request I am doing a quick write up on this. I will have to edit once I can get pictures. This was quite simple. The front washer fluid pump is the front one on the washer fluid container. I started by taking the screws holding the container in place out. Once I had the container loose I unhooked the electrical connections and just spun the washer fluid pump. The screen/nut holding it in place then fell in the container. This caused me to have to dump the contents out. I then got the new washer fluid pump and held the screen with needle nose vise grips. Once i had that in place I just slowly turned the washer fluid pump back onto the screen/nut.
This was very simple and if anything does not make sence, it will once you start doing it. Don't be afraid to tackle this one!
Cheers
dropped74 is offline   Reply With Quote
Unread 08-23-2010, 08:41 PM   #2
tonymartin
Nice one mate, gotta swap mine this month as it died last week!
Cheers
tonymartin is offline   Reply With Quote
Unread 08-23-2010, 09:32 PM   #3
rm2001wj
Did you know that you posted on the ZJ forum? I could be wrong, but I think this info would be more useful to Wrangler owners.
rm2001wj is offline   Reply With Quote
Unread 12-22-2010, 08:40 PM   #4
GreenLeader
I just replaced the pumps today on my ZJ in the same fashion. I found a vacuum hose plugged and stuffed under the reservoir too. But it was a very easy process. It took me maybe 20-30 minutes.
Red Jeep club #613
GreenLeader is offline   Reply With Quote
