Quantcast Wrangler Gas Cap & Bezel Mod - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Wrangler Gas Cap & Bezel Mod
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 08-25-2008, 11:13 AM   #31
moparrr07
bump
does anyone have a picture of one installed with the filler turned???
-Black Limited 1998 Jeep ZJ 5.2 44re 242 swap UC package- 2 inch BB, OME steering Dampner, custom cai, e-fan swap, kolak cat back
moparrr07 is offline   Reply With Quote
Old 08-27-2008, 12:15 AM   #32
Greengc4x4
bump, any answers?
Greengc4x4 is offline   Reply With Quote
Old 08-27-2008, 05:59 AM   #33
NewJeepFever
I will def be doing this, that looks great, and gives the WJ more of a "Jeep" look.
Great write up!
*Edit - Will this work on WJ's?
NewJeepFever is offline   Reply With Quote
Old 08-27-2008, 09:19 AM   #34
GraKee99
GraKee99's Avatar
Great write up!
Be the test dummy and post some pictures
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Old 08-29-2008, 06:06 AM   #35
NewJeepFever
[/I]
I think I will
Can I get the bezel from an Auto Parts store, or do I have to go to the Dealer? Anywhere online I can find it? Thanks guys!
Old 08-29-2008, 09:13 AM   #36
GraKee99
GraKee99's Avatar
[/I]
I think I will
Maybe the dealer parts department, they shouldn't be to much or you can try on auto parts store first.
Brian
WJ, WK, CJ5
Old 08-30-2008, 02:04 AM   #37
zippome
[/I]
I think I will
let us know! if it works out, this is going to be the next thing on my list
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline   Reply With Quote
Old 09-03-2008, 09:39 AM   #38
NewJeepFever
I ordered the bezel from 4WPW Sunday, and it should be here this weekend to play with. If it works, I will take pictures and describe the process for the WJ.
Old 09-03-2008, 12:09 PM   #39
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That sounds great.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 09-27-2008, 04:36 PM   #40
The Donger
Just finished mine today -
First, I tried turning the filler 180 degrees, but the plate on the top part of the filler is longer on one side, and doesn't fit. The overflow tube also hits the body underneath.
After I got it on, quite a bit of the paint was showing because of how much I trimmed it to fit, so instead of painting, I cut out a template of what was showing on a black 3-ring binder divider, and bolted it down with the 2 bottom filler bolts.
It seems as though the 96-98 version of the filler tube is different, as I couldn't turn mine. If I could've turned it, I probably wouldn't have had to trim the bezel.
1996 ZJ 4.0 4X4
Bored TB, K&N Filter (OEM Replacement), Edelbrock RPM Series Muffler
1" KOR BB & Up-Country
The Donger is offline   Reply With Quote
Old 09-27-2008, 05:34 PM   #41
SkyjacktZJ
Looks good, man. Yeah, the turning the filler tube thing didn't work for me either (see earlier post). I didn't have to cut anything to fit though. I just took a file to the back of the bezel where the high spots were and it fit. Maybe I just got lucky...
Mine - Black '95 5.2L ZJ, 6.5" RE hybrid lift, ARB Bumper, 33" TrXus MTs, Black Steelies, Magnaflow, K&N Black Jeep Club Member #50
Hers
- '99 4.0 WJ, Platinum Silver Metallic, 2" BB, 245-75-16 BFG ATs
SkyjacktZJ is offline   Reply With Quote
Old 09-27-2008, 07:01 PM   #42
The Donger
I couldn't get it to seat properly. The plate that has 4 bolts in it got in the way pretty bad. Mine up close doesn't look as good as your guys mods, but it looks pretty good further away. We'll see how it looks at night. Hopefully it doesn't stick out too bad. I'm still getting used to the look.
1996 ZJ 4.0 4X4
Old 09-28-2008, 07:02 PM   #43
NewJeepFever
I have had mine laying around for some time now, and have yet to tinker to see if it will fit on the WJ's, will play around with it tomorrow and post the results.
Old 02-11-2009, 02:48 AM   #44
zippome
sorry to bring up a post from the dead but has anyone succesfully done this with a wj? does anyone have the price or part number for the bezel? any pictures of this installed on a wj would be awesome.
Old 02-11-2009, 03:51 AM   #45
ZJ_Richie
Heres where I got mine from http://cgi.ebay.com/ebaymotors/JEEP-WRANGLER-FUEL-FILLER-GAS-TRIM-FITS-97-06_W0QQitemZ120365622661QQihZ002QQcategoryZ33556QQ ssPageNameZWDVWQQrdZ1QQcmdZViewItem
3 in. Pro Comp lift with crawlerready 2 in. spacers, longer than stock control arms, front adj. track bar with IRO hd mount, rear adj. track bar, jks discos, Currie Currectlync, black soft 8's with 32 in. Hankook Dynapro mts
Future mods: hp30, 8.8 swap, IRO's 5.5 Critcal Path Kit
ZJ_Richie is offline   Reply With Quote
Glock Forum
