Wrangler 242 swap? - JeepForum.com
post #1 of 9 Old 05-17-2013, 08:56 AM Thread Starter
massarosareloud
Wrangler 242 swap?
I've got a 96 ZJ 249 and want to swap it with a 242 from a 93 Wrangler, both have the 23 spline input. Am I missing something, or are these compatible with each other? I've looked through the sticky but can't find anything directly related to the input shafts on those 242's.
1996 Jeep Grand Cherokee Limited Edition 4.0L
3.55 axles, stock pretty much everything, except for a PSC steering gear and fuel injectors
massarosareloud is offline
post #2 of 9 Old 05-17-2013, 09:09 AM
dnuccio
i dont think the wrangler ever came with a 242. IIRC they all had 231s.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 9 Old 05-17-2013, 11:11 AM
speedbucket
Ummm....measure the exposed length......apparently you didn't read well
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #4 of 9 Old 05-17-2013, 02:13 PM Thread Starter
massarosareloud
I don't have the actual transfer case, it'd be a 2 hour drive both ways to pick it up, so I was hoping to maybe get some opinion here before I make the 4 hour drive.
This is what it says in the sticky:
93-95 V8 ZJ's: 46RH transmission, 1.55" 23 spline input shaft
93-95 I6 ZJ's with the 42RE: .840" 23 spline input (with collar)
93 I6 ZJ's with the AW4 or AX15: .750" 23 spline input
All 96-98 ZJ's: .840" 23 spline input
All 96-01 XJ's: .840" 23 spline input
92-95 XJ's: .750" 23 spline input
91 and older XJ's: .750" 21 spline input
Now, I'm pretty sure that I read correctly here that there are only ZJ's and XJ's in that list, no YJ's, TJ's or JK's...
post #5 of 9 Old 05-17-2013, 02:16 PM
speedbucket
again, i dont think 242s ever came in a yj
my 231 is from a yj, i just had to swap the input plus front output yoke bc they had 2 ujoint front driveshafts instead of the double cardan
post #6 of 9 Old 05-17-2013, 02:20 PM Thread Starter
massarosareloud
Jeez, yeah I'm sorry about that. I meant to type 231, been looking at this stuff for hours and I guess I got confused. So same question, would the input shaft from a 93 wrangler 231, match my input shaft from my 96 ZJ 249?
post #7 of 9 Old 05-17-2013, 02:23 PM
speedbucket
have him measure the exposed inpu shaft length, if the spline count matches then it should swap case for case, but because yours is a 96(post gear cut change) and his is a 93 (pre gear cut change)so you will NOT be able to swap your input into it if it doesn't match your's input length
post #8 of 9 Old 05-17-2013, 03:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
yes it matches and has internal slip yoke.
ratmonkey is offline
post #9 of 9 Old 05-17-2013, 03:47 PM Thread Starter
massarosareloud
Looks like I'm buying a 231!
