Quantcast Would you buy this rack? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Would you buy this rack?
Old 06-24-2007, 01:27 AM   #1
baileyedition
I asked about what you all thought but it was under a post for the 3.5 " lift with stock tires and i dont think it got all the looks it could have.
Im curious to find out if anyone likes its style enough that they think i could make some parts money with it...meaning do you think its sellable....could always use the help to upgrade the jeep.
heres the link for the pics.
http://www.flickr.com/photos/9235532@N06/
the specs are- O.D. 75 1/4" in length and 42 3/8" in width and 5" in height. The 5" height is to keep a slightly lower profile and allow for the easy bolt on lumber rack bars I'll be making. As a contractor I'll need it. It weighs about 60 lbs, I was easily able to carry it out and install it myself. The top is slightly smaller to give the angles for looks. The front brow i was really happy with for the sorta angry look its got. Im still looking for the right mesh to put in it, something strong like youd see on the bottom of a home depot cart. But the spare tire carrier I have all worked out. It incorporates a 5/8" threaded rod, the plastic hub centerer that came with the jeep, drilled for the 5/8" bolt and a coupling nut with handles welded to it for easy on and off. I also have the mounts for the shovel and the jack figured out, Ill install them and take pics when i get the shovel and the hi-lift to put on it.
The dimensions of the rack and placements of cross bars and mounts allow for the rack to sit down over the mounts and bring it within a 1/2" of the stock rails at the center. It also allows for unobstructed views out the moon roof.
The clamp system is super strong and uses a 1/2" grade 8 bolt welded onto the top clamp surface for rack mounting and two 1/4" bolts for the clamps themselves.
Ive had it going down the highway at 85 and no wind noise. Its finished with a Hammerite hammered gloss paint. 5$ a can for easy touch-ups.
Bumpers and Sliders are next!
98 zj ltd. 5.2L 3.5" RE Springs, Pro Comp ES 9000 Shocks, RE extd. Brake lines, KOR TB Conv. JKS Adj. rear TB, JCR 1 Ton Steering Upgrade, 2.5" exhaust to 70 series Flowmaster, K&N intake, Manik F & R bumpers, Indiglo gauges, Home made rack, a never ending string of new replacement parts lol- Bearings, bushings, Hubs, Axles, Steering box, Engine mounts, water pump, and on and on
Believe in yourself and you can overcome any obstacle!
Pics here- [url]http://www.flickr.com/photos/9235532@N06/[/url]
baileyedition is offline   Reply With Quote
Old 06-24-2007, 02:07 AM   #2
JayIV
Hells yea. Actually, I would prefer a rounded version. Or a version that mounted directly to the roof of my WJ rather than on the existing rack rails.
Jay
'94 YJ Sahara D44s F&R SOA 35''s BFG MTs 1-Ton HiSteer
4.7HO Limited WJ 4.5'' Clayton's 32''s For Sale
JayIV is offline   Reply With Quote
Old 06-24-2007, 03:16 AM   #3
j.love
1994 ZJ
Dude that thing looks great! When can I get one! , Ok I don't think I'm ready to invest,, but thats the way I feel about it.. I'ts one of the better looking ones I have seen! I am book marking this page for when im ready, probably around the end of the summer..
Whit that said.. I do have one issue.. I think most guys here will throw the occasional 2X4 or 10 of them on their racks. Is there a way to get them to clear 6" lights up there. Like making a mounting tab thats lower so the lights don't go above the rack? I wouldn't even mind seeing them out in front of the front cross bar.
I would also like to see a close up of the way the rack mounts to the rails!
Again that thing looks awesome!
David.
94 ZJ laredo 5.2 V8 soon to be 5.9!!
In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden
j.love is offline   Reply With Quote
Old 06-24-2007, 06:17 AM   #4
kenbuck
that is some excellent work. i'd certainly be interested in one.
02 TJ.
2.5" RC Progressive Lift
1" PA Body Lift
33" KM's
misc other stuff.....
kenbuck is offline   Reply With Quote
Old 06-24-2007, 07:36 AM   #5
TriKolor
Very nice...how does it mount and how heavy is it?
Tri-Kolor
96 ZJ Laredo 5.2l V8
3" Skyjacker Lift 31X10.50R15 Pro Comp M/T's
Pro Comp Black Steel series 95 Wheels
Alpine Head UnitAlpine CD Changer Infinity Reference Door Speakers
JL Audio 10" Stealthbox Kenwood Mono Amp
Don't be such a Thule!
TriKolor is offline   Reply With Quote
Old 06-24-2007, 08:01 AM   #6
a70eliminator
how heavy
60 LBS without the mesh floor. very nice job nothing like making your own one of a kind thats great. i'm guessing it's constructed of al-uminiun seems like a steel one of that size would weigh over 100 LBS am I right?
a70eliminator is offline   Reply With Quote
Old 06-24-2007, 08:09 AM   #7
zaq123
1941 MK Compass
I'd buy one
zaq123 is offline   Reply With Quote
Old 06-24-2007, 08:17 AM   #8
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Bailey,
unless you are vendor, you can't sell those here. There are steps to becoming a vendor on the main page at the top.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 06-24-2007, 10:24 AM   #9
baileyedition
Ok Hunter- dont wanna overstep here....not trying to be a vendor yet...was just curious about interest.
Its not aluminum, its 1/8" square tube steel. I didnt think aluminum would offer the strength needed for the lumber. The 60lbs is a rough estimate as its only based on my being able to carry it, throw it around and install it myself and i know it ways a little less than my 80 lb dog
I had planned on removable rails for the lumber rack attachment- that would also get you to clear the lights. Ill make all this up and finish the rack and post up some more pics in a couple weeks.
I do plan on a round version as well, this material was just easily accessible and priced right. And the woman likes sharp lines.
Ill take a close up pic of the mounts and put it on the same page the rest of the pics are on.
Thanks for the responses guys
Special thanks to j.love for putting up the pics!
Old 06-24-2007, 10:35 AM   #10
BLACKzj52
looks good man
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 06-24-2007, 10:38 AM   #11
bjl95mustang
If you did end up selling them how much do you think they would cost?
ZJ 98 5.2 LIMITED De-Badged
4.5" Lift: RE 4.5" springs,Iro rear 3.5 springs+1" spacer, RE shocks, All adjustable arms, IRO front track bar and HD bracket, Rear jks track bar, 1-Ton Steering, 242 tc, 33x12.5x15 GoodYear wrangler silent tires, 15" rock crawler rims, Aussie Locker For My 44A, 760X u-joint front axles.
Soon to come Lock Right Front Locker.
Jeep Inferno member #10
Texas Jeep Club Member #78
bjl95mustang is offline   Reply With Quote
Old 06-24-2007, 10:50 AM   #12
baileyedition
Im at about 200.00 for material right now without the mesh floor or lumber rack attachments which could push it to around 300.00 for material and then theres ofcourse something for labor. This one took two days to make but thats because of the designing to...I figure if I was going to do it (had enough interest) Id make a jig for it and have a stock of all the pieces and then could turn out probably 2 or 3 a day. Ill be better able to answer that question when Im totally finished with it.
Old 06-24-2007, 02:07 PM   #13
j.love
1994 ZJ
bailey, You know if you set up a photobucket account, you might have an easier time posting pic's Your past that 50 post mark so your ready to make the next step!
www.photobucket.com
What I was thinking with the lights is just to lower them. Once you get them below the height of the top of the rack, you wont need an attachment for a lumber rack!
Ok thinking out loud here,,, you were planing on the tire and other stuff up there... so maybe you might need more height then...
David.
Old 06-24-2007, 02:45 PM   #14
CLNinja
www.imageshack.us.tt
MUCH better
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Old 06-24-2007, 06:06 PM   #15
baileyedition
Exactly! and I dont know about you but i sure dont want to be taking my spare off every time i want to put lumber up there and some guys are running 15" wide tires (although maybe not to many on a zj) So i figured that an adjustable height lumber rack attachment would be quick on and off and easily storable.....more so than a tire anyway.
But I appreciate the thoughts on it....if you or anyone has anything else theyd like to see in a rack...please feel free to comment.
Glock Forum
