would it kill the engine? - JeepForum.com
post #1 of 16 Old 07-03-2006, 11:51 PM Thread Starter
blacdogg0124
ok sorry I posted that about the security question. I read the post going back awhile and I got part of my anwer. But can anyone just tell me if it does have a engine kill if it the alarm is attactivated? Because then I can narrow down the possibilties of why it isnt starting
blacdogg0124 is offline
post #2 of 16 Old 07-04-2006, 05:26 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Specs,
Year and model.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 16 Old 07-04-2006, 06:27 AM Thread Starter
blacdogg0124
93 Zj 5.2 It does start but it shuts off right away. I tried giving it gas when I start it and it does rev up but it still just died after a couple of seconds even if my foot is on the gas
post #4 of 16 Old 07-04-2006, 06:35 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes, if the alarm is activated, the engine will die.
Are you using the regular key or a valet key to start the engine?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #5 of 16 Old 07-04-2006, 06:39 AM Thread Starter
blacdogg0124
im guessing reg because it has the black plastic on it. and the remote doesnt work what can i do just to get it started. oh yeah the lock doesnt work either at the switch. Would going into diagnastic mode shut it off? on-off-on-off-on right?
post #6 of 16 Old 07-04-2006, 07:02 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That shouldn't kill the engine.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 16 Old 07-04-2006, 07:08 AM Thread Starter
blacdogg0124
what? I mean would going into diagnastic mode shut off the alarm because there is no way for me to do it with the remote not working or the locki switch
post #8 of 16 Old 07-04-2006, 07:10 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It may. So could disconnecting the battery for awhile.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 16 Old 07-04-2006, 07:13 AM Thread Starter
blacdogg0124
thanks ill update what do you think if I open the kick panel and give the lock wire a pulse of whatever it requires
post #10 of 16 Old 07-04-2006, 07:14 AM
jeep946
jeep946's Avatar
put the key in the rear door and unlock it. that will kill the alarm to
94 Grand Cherokee, 4.6 stroker, 7 inch custom long arm kit, 33x12.50x15 Firestone destinations m/ts, flow-master 40 series, magnaflow high flow cat, locked front and rear, super axle kits front and rear, pioneer head unit, CB on channel 10, and a B&M built transmission, switched from a 231 to a 242, 2000 Grand Cherokee steering and knuckles and brakes, no abs, wildwood adjustable proportioning valve, and lots more
jeep946 is offline
post #11 of 16 Old 07-04-2006, 07:21 AM Thread Starter
blacdogg0124
thanks for the help guys. If this stuff doesnt work im just going to go to the deal and get raped.
post #12 of 16 Old 07-04-2006, 07:35 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Wow, I wasn't expecting that last part.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #13 of 16 Old 07-05-2006, 01:36 AM
3xX
1994 ZJ
Here is something I found very helpful using google when I ran into the same problem over a year ago.
http://autorepair.about.com/library/...emote+controls
Hopefully that will help you out.
That's Not MUD, that's LOVE!
3xX is offline
post #14 of 16 Old 07-05-2006, 08:14 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Some aspect of the link may not apply because the post 1996 jeeps use the RF (radio frequency) remote, while the 93-95 and early 96 models use a IR (Infrared) remote (at least for US models). All good info though.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #15 of 16 Old 07-05-2006, 09:21 AM
wmchurch
I just disabled my alarm this weekend. For me, I pulled off the drivers kick panel and grounded the Violet / Yellow wire that comes from the drivers door. I attempted several times to arm the alarm and open it from the inside with out dis-arming the alarm and it never activated once. The security light doesn't blink either.
The correct wire is Violet with a yellow trace. I think there is one that is yellow with a violet trace, that isn't it.
FWIW, I replaced the drivers door key switch last year, only to have it fail again (or fall off the tumbler, who knows). I'm over it.
I took a few pictures, will post later.
If you don't want to disable forever, you could always hook it to a switch to ground and just hit it under the dash. That way you still have an alarm and can disable it if you have to.
1994 Jeep Grand Cherokee Limited
122kmi
5.2L all stock baby...
wmchurch is offline
Kill Engine Will Not disable!!! From Big Island ZJ Grand Cherokee Forum 36 02-03-2010 06:47 AM
Will I kill it? rcpeddie ZJ Grand Cherokee Forum 15 04-13-2008 01:18 PM
I want to kill my ZJ, help me please inv3ctiv3 ZJ Grand Cherokee Forum 21 01-21-2008 12:29 PM
Im gunna kill someone madcabbie ZJ Grand Cherokee Forum 43 03-28-2006 02:08 PM
Did I kill it? -Joe- ZJ Grand Cherokee Forum 9 12-04-2005 07:58 PM
