ok sorry I posted that about the security question. I read the post going back awhile and I got part of my anwer. But can anyone just tell me if it does have a engine kill if it the alarm is attactivated? Because then I can narrow down the possibilties of why it isnt starting
93 Zj 5.2 It does start but it shuts off right away. I tried giving it gas when I start it and it does rev up but it still just died after a couple of seconds even if my foot is on the gas
im guessing reg because it has the black plastic on it. and the remote doesnt work what can i do just to get it started. oh yeah the lock doesnt work either at the switch. Would going into diagnastic mode shut it off? on-off-on-off-on right?
what? I mean would going into diagnastic mode shut off the alarm because there is no way for me to do it with the remote not working or the locki switch
Some aspect of the link may not apply because the post 1996 jeeps use the RF (radio frequency) remote, while the 93-95 and early 96 models use a IR (Infrared) remote (at least for US models). All good info though. :thumbsup:
I just disabled my alarm this weekend. For me, I pulled off the drivers kick panel and grounded the Violet / Yellow wire that comes from the drivers door. I attempted several times to arm the alarm and open it from the inside with out dis-arming the alarm and it never activated once. The security light doesn't blink either.
The correct wire is Violet with a yellow trace. I think there is one that is yellow with a violet trace, that isn't it.
FWIW, I replaced the drivers door key switch last year, only to have it fail again (or fall off the tumbler, who knows). I'm over it.
I took a few pictures, will post later.
If you don't want to disable forever, you could always hook it to a switch to ground and just hit it under the dash. That way you still have an alarm and can disable it if you have to.
As far as disconnecting the battery, upon reconnecting the battery this enables the kill mode on the engine for me (interior and exterior lights flash but no horn). I have to disable it from a keyswitch or grounding out the wire.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
