worth the time and money?? - JeepForum.com
post #1 of 5 Old 12-30-2003, 05:17 PM Thread Starter
Kess
i have a lil bit of blow-by in my 4.0L, now the question is should i spend the money and my time to swap in a new head to get rid of this oil burnage?? or is the problem bad enough to where it wont matter if the head gets swapped or not.....thanks for ur input
also has ne one done this, how hard....doesnt sound too bad out the chiltons.....
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #2 of 5 Old 12-30-2003, 05:35 PM
xxxflhrci
xxxflhrci's Avatar
Have you done a compression test and a leak down test? How do you know that it is the head and not the rings that are bad?
xxxflhrci is offline
post #3 of 5 Old 12-30-2003, 05:37 PM Thread Starter
Kess
i just believe its the head cuz when i pull the oil cap off after running smoke comes out, not heavily, but it does......and my valve cover breather leaks oil like nutso
Kess is offline
post #4 of 5 Old 12-30-2003, 06:23 PM
xxxflhrci
xxxflhrci's Avatar
Is your PCV system working properly. Check the valve for pulsing. Sounds like it is blocked which would cause excessive pressure and a leak.
post #5 of 5 Old 12-30-2003, 07:59 PM
BlueCuda
A bad head won't cause this. A bad head gasket MAYBE but not likley. Does it burn oil? Some blow by is normal but if its chugging smoke out its terminal.
97 XJ, RE 5.5, 33x12.50 BFG MT, Exploder 8.8, 4.56s, LR rear, True-Trac Front, Custom front bumper, Durango rear with tire carrier 4.6L Stroker
BlueCuda is offline
2" lift kit for wj from ironman suspension - worth the money? VinceAustria ZJ Grand Cherokee Forum 6 12-26-2009 02:10 PM
Worth time to weld? Inavacuum ZJ Grand Cherokee Forum 4 09-21-2008 09:58 AM
Projector / Halo Headlights - Worth the money? TSFSU ZJ Grand Cherokee Forum 49 12-24-2004 01:32 AM
Worth the Money? snow1214 WJ Grand Cherokee Forum 1 12-31-2003 08:25 PM
Carsound cat worth the money? Booth ZJ Grand Cherokee Forum 2 03-15-2003 02:04 PM
