won't stay started - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > won't stay started
RIGID LED Light Blowout Sale - All Sizes, All Series, all Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiWinter & Offroad Tires
Unread 04-02-2013, 04:15 PM   #1
chickjeep98
won't stay started
I have a 98 cherokee that won't stay on after i start it. It also has a an issue where all the gauges jump all over the place and the all the lights inside turn off and on. I thought it was the alt but now it won't start and stay on. any ideas or know where to start to get it fixed.
chickjeep98 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 06:46 PM   #2
Rich93ZJ
Check the wiring to the o2 sensor for a short. Sounds like your PCM is on the fritz. The most common culprit is the o2 wiring. Does your fuel pump stay on when you turn the key?
Rich93ZJ is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 07:00 PM   #3
ratmonkey
R.I.P.
ratmonkey's Avatar
i would start with power myself. battery condition, battery cables, all grounds.
gotten any water into anything lately?
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 04-02-2013, 07:22 PM   #4
chickjeep98
everything was fine until the other night on the way home all of this started to happen and i thought it had something to do with my alt so i changed it and it started but i didn't drive it for the rest of the weekend until this morning and it wouldn't stay on. so i'm going to say that no i haven't gotten water on or in anything. battery checked out great, put new terminal ends and cleaned the ground wire that leads to the chaise from the battery. I did notice that there was a lot of corrosion leading down the inside of the ground wire but didn't think that would be a problem. i'm really hoping that it's not my computer.
Unread 04-02-2013, 08:02 PM   #5
ratmonkey
R.I.P.
ratmonkey's Avatar
i'd get that other wire replaced as well.
after you've disconnected the battery the computer needs time to relearn the idle strategy and how to drive. for some rigs, that usually need a tune up pretty bad, that can include you needing to feather the gas to keep it idling or to start it. should relearn in a few trip cycles.
though i'd look into tune up items and clean up the throttle body and idle control solenoid.
Unread 04-02-2013, 08:25 PM   #6
chickjeep98
my husband just did a complete tune up about a month or so ago and also sea foam cleaned the engine and throttle body. i'll have him change the wire and see what happens. How much do computers cost for a Cherokee with a 5.9l?
Unread 04-04-2013, 08:54 PM   #7
chickjeep98
Ttt
Unread 04-04-2013, 09:43 PM   #8
dylantheheeler
Wiggle the computer connections to see if there is any change in it starting. Try wiggling while someone else is starting it if it won't start.
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline   Reply With Quote Quick reply to this message
Unread 04-04-2013, 09:57 PM   #9
chickjeep98
We did find a couple of wires that led to the injectors that were melted or the covering started to fall off. We spliced in New wire with no change...
Unread 04-04-2013, 10:07 PM   #10
dylantheheeler
I'm referring to the C1, C2, and C3. The main connections on the front of the PCM. The PCM is located behind the coolant overflow bottle. Wiggle those connections during startup to see if it affects it.
Unread 04-04-2013, 10:15 PM   #11
chickjeep98
Ok I understand. We will try in the morning. Thank you for your help.
