Won't start - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Won't start
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 06-19-2011, 08:50 AM   #16
melk
Your headlamps are glass?
melk is offline   Reply With Quote
Unread 06-19-2011, 09:41 AM   #17
classicmetalman
Originally Posted by pub View Post
I managed to fix the alarm problem - hood closure switch was the problem!
When I finished fixing it I shut the hood and the glass fell out of the passenger side headlamp and smashed!
This is supposed to be my DD.
LOL, feeling your pain brother. In the last couple of weeks replaced the thermostat, radiator cap, PCM, Govenor pressure sensor/solenoid and catalytic converter.
Good thing I got $ growing outta my *** and I don't need it for anything else!!
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline   Reply With Quote
Unread 06-19-2011, 11:39 PM   #18
pub
yep - front lens is glass, made by hella I think. Its a UK model, don't know if they're slightly different spec. Don't personally like plastic lenses - they scratch and crackle and similar.
I think turning it over for ages trying to start it with no CPS followed by the alarm going off all the time has finished the battery off - good job I've also got loads of money and nothing better to spend it on!
pub is offline   Reply With Quote
Unread 06-20-2011, 05:16 AM   #19
melk
That's nice I'd rather have glass lenses.
You could drain your battery and then do a slow trickle charge if you have such a charger.
Unread 06-20-2011, 06:21 AM   #20
ratmonkey
Living dead mod
ratmonkey's Avatar
Kolak can get them. European lights use the h4 bulb as well
ratmonkey is offline   Reply With Quote
Unread 06-20-2011, 06:42 AM   #21
melk
I'll have to look into that.
Though I'd feel better having some sort of protection up front first... This was a few weeks ago. Had my steering wheel cut all the way, reversing in a tight arc.... Didn't quite clear that tree
ignition , start problems
