Won't shift out of 4 wheel drive! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Won't shift out of 4 wheel drive!
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-09-2008, 09:57 AM   #1
sideline4
We have a 1999 Gran Cherokee 6 cyl. Wife will shift to 4 high whenever the roads are snowy or icy. The problem is that it will not return to 2 wheel drive when roads are dry. The only way we know it is still engaged is when I make a sharp turn on dry pavement you get that binding, hopping feel in the wheel. Took it to a local garage thinking it was a linkage problem, maybe a shift rod adjustment, but he said it was a cable shift and it may be stretched. We also put new tires ups front, with a 1/4" differance between the front & rear tire height. Could that be some of the problem. Is there any quick fix to this, or how can I dis-engage this when I need to. Just don't need any major expense this time of year.
Thanks for any help in advance.
sideline4 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2008, 10:42 AM   #2
Granam73
Try backing up a little after shifting back into 2wd. That always worked for me.
Granam73 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2008, 03:08 PM   #3
iamdurkee
lol try waiting a week worked for me.
iamdurkee is offline   Reply With Quote Quick reply to this message
Unread 12-10-2008, 11:37 AM   #4
wjjeepman34
http://www.jeepforum.com/forum/f13/4x4-problem-646954/
some solutions to help you better can be found there. Good luck.
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2008, 06:18 AM   #5
sideline4
Thanks for all your help....Will try them all!
