wont shift out of 3rd - JeepForum.com
post #1 of 6 Old 05-07-2006, 07:04 PM Thread Starter
mudboggerrebel
my speedo stoped workin and now i notice it wont shift above 3rd. it shifts up to 3rd perfect but wont go to 4th or 5th.. any ideas?
JEEP GRAND CHEROKEE TOUGH
1995 jeep grand cherokee
5.2 V-8 K & N intake cut off exhaust with turn-down off the cat.
I have about 10inchs of lift... 36inch Irocks on 16inch rims. Ford8.8 rear with a Detroit lockers. 4:56 gears front and rear. NP249 transfer case . Tom Woods front and rear drive shafts. 12,500lbs. winch. 6 spot lights pointing forward 2 spot lights for reverse. custom stereo built buy me 4/12's subs pushing over 2000 watts , under-body light L.E.D.s ... Custom high steer setup. roof rack , trail ready front and rear bumpers....
mudboggerrebel is offline
post #2 of 6 Old 05-07-2006, 07:05 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Pst, you don't have a 5th gear
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 6 Old 05-07-2006, 07:07 PM
Wiley
Wiley's Avatar
It won't shift to 5th because you don't have a 5th gear. Make sure fluid is at the right level. Mine would stay in 3rd, jump to 4th, and then quickly go back to 3rd. Turns out I was just about a quart low of ATF.
Justin
1993 ZJ Laredo
5.2 V8 4" lift 31s JKS f & r track bars JKS discos Cragar Soft 8s DT 3000s OME Stabilizer
K&N drop-in Dynomax Exhaust Hella 500s Westin Safari Bar KOR Radiator Support
Dark Rosewood Jeep Club Member #5
Wiley is offline
post #4 of 6 Old 05-07-2006, 07:51 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I don't know if it pertains to a '95 or not, but someone recently said that if the speedo isn't working it could cause the tranny to go into a limp home mode where it won't shift right. Try fixing the speedo problem and see what happens.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 6 Old 05-07-2006, 08:04 PM
Derek33
Derek33's Avatar
go over your overdrive fuses/connections/button, maybe its stuck on.
Derek33 is offline
post #6 of 6 Old 05-07-2006, 08:49 PM
GreenDean
GreenDean's Avatar
is the speed seonsor on the trans also what controls the speedometer?
If it is then there is your problem right there.
400 bucks and your good to go!
GreenDean is offline
97 gc wont shift to od JD37055 ZJ Grand Cherokee Forum 10 12-02-2009 09:10 AM
93 zj wont shift out of OD that_1guy ZJ Grand Cherokee Forum 10 11-14-2009 07:36 PM
99 4.0 wj wont shift out of 1st spanky02 ZJ Grand Cherokee Forum 4 06-29-2009 12:49 PM
WK Wont Shift-ing issue 07JGC WK Grand Cherokee & XK Commander Forum 31 07-29-2008 12:17 AM
Wont shift into 4 LO Casper4x4 ZJ Grand Cherokee Forum 4 11-19-2007 01:42 AM
