Wondering about my P0161 and what it effects - JeepForum.com
post #1 of 4 Old 07-29-2009, 02:27 AM Thread Starter
ef1992
www.wjjeeps.com says the following:
Oxygen sensor heater element malfunction. O2 sensor voltage greater than 3 volts for 60 to 240 seconds.
What part of my Jeep is this effecting exactly? Put it in layman's terms please!
My CEL came on and I did the OBD and thats what I got.\
2001 Grand Cherokee Limited-4.7 V8-Quadra Trac II-Flowmaster Super 44 with 3" exhaust
ef1992 is offline
post #2 of 4 Old 07-29-2009, 06:38 AM
greasefingers
greasefingers's Avatar
1994 ZJ
The O2 sensor fine-tunes the fuel management system and keeps the emissions low. Keep in mind that the PCM does not use the sensor under the following conditions: cold engine, acceleration, or deceleration. It is basically used during constant speed. If it is bad your fuel economy will decrease.
The O2 sensor will not perform correctly unless it is hot. Therefore the engine must be at operating temperature before the PCM/ECU (computer uses it). The heater element helps to get it hot quicker which helps emissions. If the heater element, which is an integral part of the sensor, does not work (because it is broken) then the PCM stores a code.
Simply have it replaced with an OEM type only.
Oxygen sensors are probably the least reliable sensor on any vehicle. The volt output should ave around 0.45 volts
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 4 Old 07-29-2009, 03:01 PM
20jeepwj00
there is a pcm flash for 02 sensor heater failures,if your pcm has never been updated this will probably fix you problem.
20jeepwj00 is offline
post #4 of 4 Old 07-29-2009, 03:31 PM
rm2001wj
rm2001wj's Avatar
Your 01 WJ has 4 oxygen sensors. The actual trouble code (format P0xxx) will tell which one has the faulty heater. Although greasefingers is corrrect, it is also true that the upstream sensors are somewhat more important for setting the mixture correctly. Your code refers to a downstream sensor.
rm2001wj is offline
The effects of BB Lifts xa310165 WK Grand Cherokee & XK Commander Forum 7 12-19-2009 01:41 AM
Error code P0161 which oxygen sensor slick1474 ZJ Grand Cherokee Forum 2 10-22-2009 07:20 AM
Code P0161 here one day, next day gone. WHAT HAPPENED??? ef1992 ZJ Grand Cherokee Forum 14 07-20-2009 06:12 PM
P0161 - As soon as I started it this morning! WTH! HELP! Polaris Junkie ZJ Grand Cherokee Forum 7 08-28-2006 08:08 AM
P0161 - Which O2 Sensor? Camo ZJ Grand Cherokee Forum 8 03-14-2006 03:38 PM
