Won't start - Page 2 - JeepForum.com
post #16 of 21 Old 06-19-2011, 09:50 AM
melk
Your headlamps are glass?
melk is offline
post #17 of 21 Old 06-19-2011, 10:41 AM
classicmetalman
Originally Posted by pub View Post
I managed to fix the alarm problem - hood closure switch was the problem!
When I finished fixing it I shut the hood and the glass fell out of the passenger side headlamp and smashed!
This is supposed to be my DD.
LOL, feeling your pain brother. In the last couple of weeks replaced the thermostat, radiator cap, PCM, Govenor pressure sensor/solenoid and catalytic converter.
Good thing I got $ growing outta my *** and I don't need it for anything else!!
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #18 of 21 Old 06-20-2011, 12:39 AM Thread Starter
pub
yep - front lens is glass, made by hella I think. Its a UK model, don't know if they're slightly different spec. Don't personally like plastic lenses - they scratch and crackle and similar.
I think turning it over for ages trying to start it with no CPS followed by the alarm going off all the time has finished the battery off - good job I've also got loads of money and nothing better to spend it on!
pub is offline
post #19 of 21 Old 06-20-2011, 06:16 AM
melk
That's nice I'd rather have glass lenses.
You could drain your battery and then do a slow trickle charge if you have such a charger.
melk is offline
post #20 of 21 Old 06-20-2011, 07:21 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Kolak can get them. European lights use the h4 bulb as well
ratmonkey is offline
post #21 of 21 Old 06-20-2011, 07:42 AM
melk
I'll have to look into that.
Though I'd feel better having some sort of protection up front first... This was a few weeks ago. Had my steering wheel cut all the way, reversing in a tight arc.... Didn't quite clear that tree
melk is offline
ignition , start problems
No start/hard start in/after heavy rain. BenzB ZJ Grand Cherokee Forum 1 03-08-2011 07:11 PM
Hard Start---> No Start. Fuel pump? please help Eddmcm228 ZJ Grand Cherokee Forum 5 02-13-2011 11:44 AM
Rough start, sounds like a diesel after start up until warm.. SteelBlue_WJ ZJ Grand Cherokee Forum 7 10-05-2009 08:39 PM
bypassing the factory Start mechanism (push button Start) Jey109 ZJ Grand Cherokee Forum 16 08-30-2009 07:24 PM
Hot Start Problem.... Cold Start Injector??? Mase ZJ Grand Cherokee Forum 3 02-03-2003 10:33 PM
