Won't shift out of 4 wheel drive! - JeepForum.com
post #1 of 5 Old 12-09-2008, 08:57 AM Thread Starter
sideline4
We have a 1999 Gran Cherokee 6 cyl. Wife will shift to 4 high whenever the roads are snowy or icy. The problem is that it will not return to 2 wheel drive when roads are dry. The only way we know it is still engaged is when I make a sharp turn on dry pavement you get that binding, hopping feel in the wheel. Took it to a local garage thinking it was a linkage problem, maybe a shift rod adjustment, but he said it was a cable shift and it may be stretched. We also put new tires ups front, with a 1/4" differance between the front & rear tire height. Could that be some of the problem. Is there any quick fix to this, or how can I dis-engage this when I need to. Just don't need any major expense this time of year.
Thanks for any help in advance.
sideline4 is offline
post #2 of 5 Old 12-09-2008, 09:42 AM
Granam73
Try backing up a little after shifting back into 2wd. That always worked for me.
Granam73 is offline
post #3 of 5 Old 12-09-2008, 02:08 PM
iamdurkee
lol try waiting a week worked for me.
iamdurkee is offline
post #4 of 5 Old 12-10-2008, 10:37 AM
wjjeepman34
http://www.jeepforum.com/forum/f13/4x4-problem-646954/
some solutions to help you better can be found there. Good luck.
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline
post #5 of 5 Old 12-11-2008, 05:18 AM Thread Starter
sideline4
Thanks for all your help....Will try them all!
2 wheel drive swap to 4 wheel drive papitt ZJ Grand Cherokee Forum 15 08-02-2010 11:13 PM
how can i make a all time 4 wheel drive Cherokee in to an optional 4 or 2 wheel drive Harp90 ZJ Grand Cherokee Forum 16 09-09-2009 01:09 PM
O5 Won't shift into drive or reverse... mkstarks WK Grand Cherokee & XK Commander Forum 2 01-07-2009 05:29 PM
HELP!! 96 GRAND CHEROKEE! CANT SWITCH FROM 4 Wheel drive to 2 wheel drive 4x4cherokee96 ZJ Grand Cherokee Forum 0 10-05-2008 07:51 PM
Quadra-Drive 4-wheel drive system genislav ronen ZJ Grand Cherokee Forum 0 11-17-2007 12:11 PM
