Won't get into last gear - JeepForum.com
post #1 of 20 Old 06-04-2012, 08:17 PM Thread Starter
orangeafroman
95 ZJ 5.2, tranny issue I guess.
I have a rebuilt tranny with a year warranty, it's been over a year.
Problem is I'll accelerate, everything's fine, will change gears at about 30-35 mph, but then won't switch again. Even when I get up to 60 mph, the RPMs just get up between 2 and 3,000.
Questions
A) Is this an automatic 'take it to the tranny shop' situation, or can I do something to fix it?
B) I live 2 hours from the nearest city, will driving it there mess it up more? Should I drive slower than normal to keep RPMs under 3000?
I've done a lot of work on it, but tranny's are over my head. Any help or advice would be welcome.
orangeafroman is offline
post #2 of 20 Old 06-04-2012, 10:46 PM
jnicewan
Is this something that just happened and now it wont shift at all or has it been a on going problem/intermittant type concern? When you are driving and it should be in 4th, if you let off the gas does it have engine braking or does it just coast down freely? If there is no engine braking then you probably have problems with the o/d clutch. Does the T/C lockup in 3rd gear if you press the o/d button to cancel o/d?
Most of the time the electronic side of 4th gear fail it will set a DTC, you might check for codes.
jnicewan is offline
post #3 of 20 Old 06-05-2012, 01:59 AM Thread Starter
orangeafroman
DTC?
I can't really tell about the braking. It's only happened recently, and I've only driven it a mile or two at a time.
If it's an overdrive thing, is it safe to drive 100+ miles to an autoshop?
post #4 of 20 Old 06-05-2012, 03:38 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Do you have cruise control functionality?
Check engine light on? If so, what's the code? (key on,off,on,off,on within five seconds, watch the od off button flashes for Trans codes and the cel.for engine codes.)
ratmonkey is offline
post #5 of 20 Old 06-05-2012, 08:19 AM Thread Starter
orangeafroman
no check engine light on at all.....don't know about cruise control, will have to test that out. I'm going out of town for a few days, gonna drive my other car.
I'll update about the CC next week.
post #6 of 20 Old 06-05-2012, 10:01 AM Thread Starter
orangeafroman
Actually tested it this morning before leaving...
whether the overdrive was on or off, there was no difference. Is this good or bad?
What's the next step? Again, no check engine light.
post #7 of 20 Old 06-05-2012, 10:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
No cruise?
Start with the brake switch
post #8 of 20 Old 06-07-2012, 10:39 PM Thread Starter
orangeafroman
What do u mean start with the brake switch? Buy a new one? Where is that?
post #9 of 20 Old 06-07-2012, 10:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The brake/stop lamp switch at the pedal.
post #10 of 20 Old 06-08-2012, 07:42 AM Thread Starter
orangeafroman
What about it? Sorry, I can do things, but WHAT to do-I need it spelled out for me.
post #11 of 20 Old 06-20-2012, 02:35 PM Thread Starter
orangeafroman
can anyone help?
If not, is it able to be driven 2 hours to the nearest shop? Should I drive slowly?
Any help would be appreciated, thanks.
post #12 of 20 Old 06-20-2012, 02:40 PM
PolkaPower
Just do simple google search for ZJ brake lamp switch.
PolkaPower is offline
post #13 of 20 Old 06-20-2012, 03:33 PM Thread Starter
orangeafroman
will do, thanks.
How does a brake lamp switch prevent it from going into 5th? I'd like to learn as I go.
Also, is it wise to drive it slower (40-50 mph) to town, or does it not matter? Will going 70-80mph do further damage?
post #14 of 20 Old 06-20-2012, 03:40 PM
Scopez
1994 ZJ
I don't know much about transmissions, but my wild guess would be the overdrive solenoid. Just sounds like it wont go into 4th gear (you're transmission has 3 normal gears, 4th gear is overdrive.)
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #15 of 20 Old 06-20-2012, 03:43 PM
AcidAnton
Czech OffRoader
AcidAnton's Avatar
2005 WK
Originally Posted by orangeafroman View Post
will do, thanks.
ZJ's don't have a 5th gear?
19931995 46RH 4-speed automatic 5.2 L (318 CID)
05 WK 5.7 QDII | Modified OME HD Lift | Bilstein 5100/5125 | Firestone Destination M/T 285/70/17 | 1.5" Wheel Spacer
Silver WK Club Member #88
HEMI Club Member #80
AcidAnton is offline
bad clicking from trans in park and gear won't go in to drive untill 2nd gear leechris ZJ Grand Cherokee Forum 4 04-23-2009 08:54 AM
WJ ni 1st gear starts in 2nd gear mike1coolguy88 ZJ Grand Cherokee Forum 17 04-11-2009 11:17 AM
PS gear box Casper4x4 ZJ Grand Cherokee Forum 6 03-13-2008 12:33 PM
'94 231, which gear cut? SBlackfoot ZJ Grand Cherokee Forum 11 02-20-2008 07:07 PM
Gear Oil GroundClearance ZJ Grand Cherokee Forum 9 12-10-2005 09:06 PM
