wobbling when i hit a bump - JeepForum.com
post #1 of 5 Old 03-17-2003, 10:16 AM Thread Starter
demtjcj
i just got a 93 gc. when i am going highway speeds, and i hit a bump and my steering wheel was just going back and forth really quickly. like a bad wobble. i think the ball joints are bad but not sure if thats it. let me know
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #2 of 5 Old 03-17-2003, 07:15 PM
Beachead19
Beachead19's Avatar
hmmm...steering stabilizer could also be the problem, sounds like bumpsteer to me.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #3 of 5 Old 03-17-2003, 07:33 PM
Swamp Boy
Swamp Boy's Avatar
Ditto bump steer. But you can check your balljoints by jacking
up your jeep and grabbing the wheel give it a good tug front and
back if you hear a click or feel alot of movement could be.
You could also have someone else wobble while you look to see
where the motion is. Pitman arm, Balljoints , whathave you.
Good luck
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #4 of 5 Old 03-18-2003, 02:29 AM Thread Starter
demtjcj
isnt bumpsteer from lifting your jeep. i wasnt sure. i thought bal joints, tir rod ends, steering stabilizer.
demtjcj is offline
post #5 of 5 Old 03-18-2003, 06:36 AM
Howler
Bump steer happens only when you hit a bump. Usually cased but a bad steering stabalizer. Death Wobble is when you lift you vehcile and it wobbles at a certain speed. Sometimes it happens some times it doesn't. DW is usually cased be a loose bolt in the steering or suspension componnents.
Howler
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
wobbling down the road ZJMike0932 ZJ Grand Cherokee Forum 8 05-15-2009 10:19 AM
wobbling steering..normal? luckyjeep ZJ Grand Cherokee Forum 9 03-06-2009 11:18 AM
wierd wobbling? Mudzilla6661 ZJ Grand Cherokee Forum 5 02-10-2009 07:20 PM
Wobbling headlight sportsdevil333 ZJ Grand Cherokee Forum 10 02-08-2009 12:18 AM
D30 pinion wobbling MuddyLuxury ZJ Grand Cherokee Forum 9 07-09-2008 10:59 AM
