#16 | |
To help you make your mind up, compare tire prices for 15, 16 and 17. You can save big with 15's. Also if you plan on wheeling and airing down tires stay on the 15's better. If you dont mind polishing your rims after a good day of wheeling, mudding and rock rash go with polished. I sold my polished rims and went to steelies. A hammer and black paint and they are as good a new.
_____________________________________ 01 Grand, 6in lift, 33's, Aussie locked 30/35, front disco's, home made rock rails, Surco rack, grille guard, front and rear hitch, t-max 12500lb hitch winch, rock lights, TJ transfer skid plate, OBA and a few other things. ![]() ![]() ![]() ![]()
My Build thread -- GCJEEPING's build/mod thread-It's a green thing... Last edited by gcjeeping; 03-29-2009 at 11:08 AM.. |
#17 |
ok so im gonna go with a soft 8 16x7 5on5 with a 265/70/r16
any changes before i drop the 600 for them? cause im sooo lost with this stuff |
#18 |
GCJeeping - Are you suggesting the 15's are the way to go here? Do you need to do anything to the calipers at this size as stated earlier?
getITdirty - did you change your mind from 15's to 16's? What was the clincher there....? Cheers Chumby. |
#19 |
the clincher is theres almost no space between my front calipers and the inner part of my stock rims so id rather be safe then sorry and go with the 16
plus i just like 16s better and should fit my tires better |
#20 | ||
BFGoodrich All-Terrain T/A KO from tirerack.com Size: 265/70R16 (30.6x10.4R16) Price: $197.00 (each) Size: 31X10.5R15 Price: $135.00 (each) I have only seen two post or so by people who say the steelies hit the caliper and they fixed it with very minor grinding. I have at least 1/4 to 3/8 clearance on mine. But I have D30/35 so if you have a 44a in the back it may be closer. His stock aluminum rims are thicker than steelies. I had nice polished rims on mine until one day i got stuck in mud and spun them. Then they were scratched brushed aluminum looking. Couldnt get them to buff out. Got rid of those and got the steelies. A hammer to fix rock dings and black spray paint if the paint gets bad and they look like new. Quote:
_______________________ 01 Grand, 6in lift, 33's, Aussie locked 30/35, front disco's, home made rock rails, Surco rack, grille guard, front and rear hitch, t-max 12500lb hitch winch, rock lights, TJ transfer skid plate, OBA and a few other things. ![]() ![]() ![]() ![]() |
#21 |
I have 15x8 alloys, and they fit fine.
1998 Dodge 2500 QC LB 4x4 675whp 1450wtq 12v, Suncoast trans, D80, 35" Red Letters 2002 WJ Limited 4.7 HO, 6.5" LA, 37's, JK 44's SOLD
#22 |
wait i got an idea
someone help if i got these http://www.jcwhitney.com/autoparts/ItemBrowse/c-10108/s-10101/p-100000383171/mediaCode-ZX/appId-100000383171/Pr-p_CATENTRY_ID:100000383171 what size soft eights would i need cause theyre cheaper and i could still get some travel in the wheel wells and would it work with a 2 inch bb thanks |
#23 |
Built and Supercharged 47
those are tiny, just an fyi, shorter by around 2 inches, plus those things will balance like crap AND ride like junk, they are an OFFROAD tire haha, you get what you pay for :/
Built Beater 01 WJ MY BUILD THREAD Swapped, SUPERCHARGED Locked, Lifted and Long Armed. 02 Cummins. It has a smoking problem, And it wont quit. K8 GSXR 1000- Jardine,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, B&N |
#24 |
yeah i think im just gonna put the bb on and then ride my stock tires till theyre bald (like 5000 miles) then worry about bigger ones
my stock tires do pretty damn good in the sand and mud |
#25 |
Wicked Pissah
I have a 3'' lift, 16x7 soft 8's, with 4'' back space, and 245/75/16's. Tire sizes vary so be sure to check manurfacturer specs. 245/75/16 are normaly 30.4'' wich would be good for a BB. But mine are more like 30.9''... basically 31's. I had to trim abit off the front bumper cover.
Here's mine: ![]()
2004 WJ Laredo-selectrac 242-I6- Amsoil drop in filter-Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -OME SD-40 Steering Stabilizer-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck Built 44hd for sale Still to come: Flowmaster 50suv Western Mass 4X4 Club October 2011 GCOTM Winner |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
