WJ Wheel Bearing Replaced 2 Times In Less Than A Year. - JeepForum.com
post #1 of 14 Old 07-11-2009, 10:18 PM Thread Starter
JoeBrad
2002 KJ Liberty
So I have replaced my front drivers side wheel bearing twice in a few months. The first time I replaced it there was no noise for a month or so... then it came back. The second time there was noise the instant i drove it out of the garage, it was the same as before. The noise still sounds like it is coming from the drivers side/front. Just wondering if anyone has any ideas of what it could be. I already have the oem replacement here ready to replace again just wanted to know anything I should look for this time.
JoeBrad is offline
post #2 of 14 Old 07-11-2009, 10:31 PM
xJoshxx
2012 WK
Have you Ball Joints check and Mybe you have a Bent Axle causing your stuff to run out. Also mAke sure the rotor has proper run-out also
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 14 Old 07-11-2009, 10:47 PM
elmer_fud
by OEM does that mean you are getting the bearings from/replaced at the dealership? If not what brand are you using?
also check the CV joints
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #4 of 14 Old 07-12-2009, 06:21 AM
TMCXJ
Probably stating the obvious here... but ---- torque. I know I know. But that spindle nut has to be at 175 ft.lbs. and the 3 hub bolts at 75. And most torque wrenches only go to 150 ft.lbs. Sorry for peeing on your flipflops if you tightened them properly. I just know of people who go around saying as long as it's "tight," that's good enough. And then they're replacing the bearing units twice a year and bad mouthing Jeeps, or the parts brand, or both, when it was neither.
You don't describe the noise -- it's possible that it's the CV/U-joints. Balljoints. Brakes... anything else in that area.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #5 of 14 Old 07-12-2009, 07:28 AM
cmonson
you need to describe the noise...
does it get worse going around a corner? Is it constant? When the old hub was removed, who did it turn?
cmonson is offline
post #6 of 14 Old 07-12-2009, 07:32 AM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Definitely make sure you torque is set properly.
WALTER
walter_da_jpr is offline
post #7 of 14 Old 07-12-2009, 11:12 AM Thread Starter
JoeBrad
2002 KJ Liberty
the sound is a loud roaring noise coming from the left drivers side wheel. When I make sharp turns I can hear it grinding more and more. If the torque was off a few pounds it would make that big of a difference? I have been replacing the whole bearing/hub assembly everytime.
JoeBrad is offline
post #8 of 14 Old 07-12-2009, 12:19 PM
TMCXJ
Off a "few" pounds, no. Especially since the precision will vary slightly from one wrench to another. Off by 25 ft.lbs.? yeah, it'll matter. And if you've got a 150 and you need 175, you're guessing at best -- you're almost certain to be over or under by a good bit.
There are definite ways around this, and one is to make or buy (good luck finding one!) an extension, quite similar to serpentine belt tool extensions. The serp belt ext are just not heavy enough to handle the force required. Then you can calculate the increased length and appropriately adjust the torque wrench so that it will produce the proper torque at the "new" length. It's a bit more work, but then again, how much more work is invovled in having to do it over and over again because it wasn't right the first time?
The bearing/hub is a unit and you're right to replace the "whole" thing, because it IS a whole thing. Servicing them is so very much not worth it as to be impractical.
Given the grinding that you're experiencing, I'd be inclined to ALSO (not instead of) suspect the joints. BTW, CV's or u-joints on your front axle shafts?
TMCXJ is offline
post #9 of 14 Old 07-12-2009, 01:56 PM
gatorayde
^ WJ's only came with CV's up front.
Sounds like a bad install, you have to get those torques right. Borrow a torque wrench from a friend or buy one. One way or another, you have to get the torque's right to rule out a bad install.
gatorayde is offline
post #10 of 14 Old 07-12-2009, 02:22 PM Thread Starter
JoeBrad
2002 KJ Liberty
so basically its just that the bearing that has been crushed putting it in a bind causing the noise and the bearing to wear at a faster rate. ill check it out today.
JoeBrad is offline
post #11 of 14 Old 07-12-2009, 02:25 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
rotate tires?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #12 of 14 Old 07-12-2009, 02:31 PM Thread Starter
JoeBrad
2002 KJ Liberty
already rotated.
JoeBrad is offline
post #13 of 14 Old 07-12-2009, 02:34 PM
TMCXJ
Yeah I know that the axleshafts came with cv's, but isn't it possible to swap in u-joints anyhow? They're still a dana 30 axle, so....? My thoughts were that since it could be either/or at this time, it would help to know which. The sound produced by bad cv's is a wee bit different from u-joints. YMMV.
TMCXJ is offline
post #14 of 14 Old 07-12-2009, 03:10 PM
gatorayde
Unless you are running ~33-35's or bigger (I give the range because everybody wheel's differently), the price is not worth the extra $$ to swap the CV's for U joints. I believe the only U joint's made for the WJ also come with cromo's so even if you do have strong shafts/joints, your R&P is now the weak spot, not exactly an ideal situation.
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
wheel bearing replaced again - yet still noisy rubbersidedown ZJ Grand Cherokee Forum 2 08-12-2008 05:12 PM
I've replaced the fan relay 3 times Knoxes ZJ Grand Cherokee Forum 12 07-22-2008 12:05 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
Anyone ever replaced a steering wheel???? 1badWeJee ZJ Grand Cherokee Forum 3 05-17-2006 01:42 PM
