WJ tweeter upgrade - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > WJ tweeter upgrade
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 07-12-2007, 11:25 AM   #1
maxpowrbmw
WJ tweeter upgrade
what have people been putting in their WJ's for tweeter upgrades? can you fit 3 1/2 inch tweeters in there?
maxpowrbmw is offline   Reply With Quote
Unread 07-12-2007, 12:45 PM   #2
UTBREN
If yours are busted which happens often, you can get the factory 2.5 speakers on ebay and get some bassblockers from crutchfield to install on the positive wire for each speaker so the dont blow again. ( You can do this on your own )
The speakers will run ~$50ea and $10ea for the bassblockers.
If you want to put in some 3.5 in or any other speaker you are going to have to cut the dash and prepare a custom housing for the speaker. ( You will probably end up paying someone to fab this job for you )
UTBREN is offline   Reply With Quote
Unread 07-12-2007, 01:04 PM   #3
doggboy
You can fit several different 3.5 inchers in there. Blaupunkt and Infinity are a couple off the top of my head. Just look for a shallow model. The replacements are pretty low quality and cost more than some 3.5's so I would get the 3.5s.
Do a search over on JU, there are tons of threads on this topic.
doggboy is offline   Reply With Quote
Unread 07-12-2007, 01:59 PM   #4
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I fit 3.5" speekers in mine... I had to do alittle fab work to secure them correctly.
2013 FR-S
BlaineWasHere is offline   Reply With Quote
Unread 07-12-2007, 05:07 PM   #5
maxpowrbmw
fabrication isn't a problem for me...the speakers aren't gone but they are on their way out the door...i have also heard of people fixing them with silicone or something. any opinions on that?
Unread 07-13-2007, 06:55 AM   #6
quickfix
Try here http://www.12positive.com/ I'm saving the money up to buy them for my 99' But I know that my 98' has not speakers up front just three way 6X9's in the front doors I get great sound.
quickfix is offline   Reply With Quote
Unread 07-13-2007, 11:18 AM   #7
Airborne Lee
I just went through this with both of my WJ's.
I replaced one speaker on each of the WJ's with the cheep 2.5" from the on line site. Worked great.
When I was forced to replace the second front speaker on each they only workded for a few hours. I went to the $tealership and purchased two (one for each WJ) and installed in each jeep.
Works great again. It turns out that the cheep speakers are just too high resistance. the factory 2.5 ohm's brought the total resistance back down in line.
So, $5 for the cheep on line speaker and 60 for the factory speaker. I spent 65 dollars on each WJ for new front tweeters. Problem solved.
please buy this NEW IN BOX:JK Rugged Ridge Light Bar
2013 JK Rubicon, Commando Green, CB, GPS, KC lites
KC Jeep Club Info - M416 Trailer Project
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline   Reply With Quote
Unread 07-15-2007, 10:05 AM   #8
2000 wj
I just order new tweeters from that site that QUICKFIX posted,they look good and 1/2 the price.They are also name brand DELCO I hope they are good.
2000 wj is offline   Reply With Quote
Unread 07-16-2007, 09:31 AM   #9
HiCountry88
How would these work in the dash of a wj? I'm not a audio guy so just wondering.
http://www.partsexpress.com/pe/showd...number=270-034
or these:
http://www.partsexpress.com/pe/showd...number=264-812
HiCountry88 is offline   Reply With Quote
Unread 07-16-2007, 09:42 AM   #10
JayIV
I would just get a set of 3.5s off ebay. Fitment is not a big issue at all and can be taken care of with a hot pocket knife.
Jay
'94 YJ Sahara D44s F&R SOA 35''s BFG MTs 1-Ton HiSteer
4.7HO Limited WJ 4.5'' Clayton's 32''s For Sale
JayIV is offline   Reply With Quote
Unread 07-16-2007, 10:46 AM   #11
UTBREN
The mounting in your jeep wont match the speaker housing and you will have to add to the housing to make them compatible with these new speakers. (Not that big of a deal)
It will take less time to install if you order the factory speakers.
Whichever speaker you choose get bass-blockers to install in the speaker wire to prevent the new speakers from blowing out like your old ones.
Unread 07-16-2007, 10:52 AM   #12
Airborne Lee
or these:
those 2.5" are the one's that I bought.
Read my post just above.....
One will work, two will not. Not sure about the 3". The ohm's are lower but I suspect you'll fabricate something for the install and find they two will not work for long.
Unread 07-19-2007, 04:58 PM   #13
2000 wj
I am trying to order the speakers that QUICKFIX posted the site for ,but Iam not getting any replys.Are these the ones that AIRBORNE LEE has tried.Does anybody know about this company www.12positive.com and how to contact them.Has anybody used their tweeters.
Unread 07-19-2007, 06:53 PM   #14
Thorvald
I just replaced my blown ones with a pair of Infinity Reference 1021t
1" textile dome tweeters. They come with an in-line crossover as well.
http://www.infinitysystems.com/car/p...=US&Region=USA
I used the mounting plates available on ebay, slightly modified them to fit and voila! Killer sound again and known good brand. However you could make your own from plexi-glass by using the old speakers as templates and then cut to size.
I ordered them from Crutchfield Canada and had them in a few days, good service!
http://www.crutchfieldcanada.com/Pro...0AD&click=1407
http://www.crutchfield.com/S-kGxUHqC...ter&i=1081021T
Thorvald is offline   Reply With Quote
