WJ transmission lag/slip - JeepForum.com
post #1 of 6 Old 10-04-2009, 04:14 AM Thread Starter
fizzer
So my 99 WJ 4.0L tranmission slips when shifting from 2nd-3rd. It only happens if im at rpms higher than three. if i keep it around two it dosent slip.Now just yesterday i noticed it slipping from 1st-2nd.should i get the fluids changed, not sure when its been done bought the car 3 months ago. some people said not to change it cuz it has high miles 99,000. should i use lucas, or rebuild it. What do you guys think is the problem and how can i fix it.
fizzer is offline
post #2 of 6 Old 10-04-2009, 08:15 AM
cmonson
the theory behind NOT changing the fluid if it has never been changed is that the clutch discs use the dirty fluid to grab eachother.
I am a believer in just changing the fluids at regular intervals and NOT flushing.
saying that, pull the dipstick out and see if the fluid smells burnt.
It does sound like you may be in for a rebuild however. Nice part is that you can keep the RPM's down at shifts and you will probably be able to put on MANY more miles so that you can either find a used unit or reman whichever way you want to go.
99K miles is very premature for a tranny to go. Sounds like someone didn't take care of changing fluid/flter. For future refference it is a good idea to change it every 20K miles or even less.
cmonson is offline
post #3 of 6 Old 10-04-2009, 11:43 AM
owenswj
Have the bands been adjusted? Have you thought about adjusting the TV cable. Mine did the same thing until I adjusted the TV cable. Do a search to learn how.
owenswj is offline
post #4 of 6 Old 10-04-2009, 04:51 PM Thread Starter
fizzer
so i should check the tv cable, should i change the fluids or flush it or leave the fluid the way it is. also should i change the filter. some people said check the governor pressure sensor and solenoid what do you guys think of that. what other parts should i check to see if they are working proper.
fizzer is offline
post #5 of 6 Old 10-05-2009, 09:59 PM
owenswj
If your fluid looks ok and doesn't smell burnt it may be ok. TV cable is a free fix for you to do first.
owenswj is offline
post #6 of 6 Old 10-05-2009, 10:12 PM
the88thpianoman
2003 WJ
This more or less worked for me. My trans used to, at light throttle and low rpm, be unable to decide between first and second, and would rapidly try to switch back and forth until I gave it more throttle. I pulled out the TV cable all the way (love the way it shifts at lighter throttle now), but at a certain point in heavy throttle, it'll shift to second, then try to shift back to first but default to neutral and rev till I let off the throttle. So I guess it didn't solve the problem per say, but change it so that I encounter it far less often. Gonna roll with that for now, though.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
Transmission Slip 01grander ZJ Grand Cherokee Forum 1 12-26-2009 12:13 AM
Transmission Slip and Mainteence bkloos ZJ Grand Cherokee Forum 8 12-18-2009 08:31 AM
96 ZJ Transmission Slip MylesNT ZJ Grand Cherokee Forum 1 03-03-2009 09:43 AM
ZJ Transmission Slip 95Limited ZJ Grand Cherokee Forum 0 09-18-2008 07:42 PM
what would cause transmission to slip into neutral at start-up only? mrjeep ZJ Grand Cherokee Forum 8 07-29-2006 07:05 PM
