WJ still overheating - Page 2 - JeepForum.com
post #16 of 25 Old 09-22-2009, 02:47 PM
WJroadwarrior
not trying to be a smart *** but do you do a lot of wheeling in the mud or dirt roads..
i know i searched and searched for the problem with mine and i took a hose to it on day and about 20lbs of mud and dirt came out or the coils from where it built up over all teh wheeling trips... the running temp dropped almost 20 degrees...
just a thought
WJroadwarrior is offline
post #17 of 25 Old 09-22-2009, 03:25 PM
dougy147
Originally Posted by 00RedWJ View Post
I had the exact same problem. The fan was spinning but not fast enough to move air through the radiator and the car would overheat in traffic. Replaced the fan motor 2 years ago and the temp needle has never moved past dead center since. When the fan kicks on now you can feel the hot air being drawn through the radiator.
I believe these bad fan motors are drawing too much current and either frying the relays and burning up the plug that connects to the relay.
Originally Posted by G-Wagon00 View Post
No not usally. It hasn't done that since I replaced the fan relay switch
I think what RedWJ said makes a lot of sense. The fan is probably working now, but not to it's full capacity. If you toast another fan relay, I would call this theory confirmed.
Originally Posted by SwayzePDX89 View Post
Have we thought about pulling codes when it over heats yet? X2
Good idea, if the CEL is on. I don't know that anything of much use would come up for overheating.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #18 of 25 Old 09-22-2009, 05:18 PM
SwayzePDX89
2003 WJ
Good idea, if the CEL is on. I don't know that anything of much use would come up for overheating.[/QUOTE]
Cause that will at least give the the exact problem why your fan is not turning on...if its relays the code "P1491'' will pop up... So you can keep playing around and find the exact problem or you can make a simple mod and install a switch that gives you control of the fan rather then randomly looking down at your Temp and your WJ is overheating cause a relay went out again. I did the switch and have no issues and have posted a thread on how exactly I did it.
SwayzePDX89 is offline
post #19 of 25 Old 09-22-2009, 05:31 PM Thread Starter
G-Wagon00
how do i check my codes?
Looking for 04 Limited Grille, Tow Hooks for WJ(Rustys or OEM),.
nightcrew # 81
G-Wagon00 is offline
post #20 of 25 Old 09-22-2009, 05:57 PM
dougy147
If the fan relay os the problem yes, that would help. I guess I asumed the light was not on since it wasn't mentioned. If the light is on it's probably always a good place to start.
To check codes start with the key jn the off position and cycle the key between the off and on positions 3 times. The third time your in the on position leave it there and look in the odomotmer. It will display codes and then done. You can look the codes up at wjjeeps.com
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
post #21 of 25 Old 09-22-2009, 06:03 PM
SwayzePDX89
2003 WJ
go out to your car and put the key in the ignition flip the key till the gauges/miles turn on. Then what you wanna do is rapidly Tun the key
''On-off-On-off-On.
Your gauge will then go from telling your miles to reading out any codes that might be effecting your car. It will say done regardless if any codes or not pop up. So keep trying till it happens "its kinda tricky the first try." but if the code "P1491" then you know its not your fan its just the relay
post #22 of 25 Old 09-22-2009, 06:09 PM Thread Starter
G-Wagon00
Ok i just went out and did that like 10 times and it said done everytime
nightcrew # 81
post #23 of 25 Old 09-22-2009, 06:12 PM
SwayzePDX89
2003 WJ
So...your fan IS working?
post #24 of 25 Old 09-22-2009, 06:24 PM
dougy147
Have you replaced the radiator cap? When you refilled the coolant, did you use pre-mixed or mix the coolant 50/50 with water? A bad/loose cap or too rich a coolant mixture will lower the boiling point of the coolant, causing the condition you are describing, per the FSM.
The Past
95 ZJ Laredo 4.0
The Present
dougy147 is offline
post #25 of 25 Old 09-22-2009, 06:43 PM Thread Starter
G-Wagon00
i can do that next. my winsheild also likes to fog up like all the time someone said that was another sign of heater core needing to be replaced
nightcrew # 81
01 wj 4.0 overheating still!!! Nburns24 ZJ Grand Cherokee Forum 21 04-02-2009 12:35 PM
overheating dude979 ZJ Grand Cherokee Forum 7 03-20-2009 10:49 PM
Overheating ben98zj ZJ Grand Cherokee Forum 5 03-06-2009 03:05 PM
My wj is overheating. Forbidinworks ZJ Grand Cherokee Forum 5 03-02-2009 01:40 PM
Overheating JForestZ34 ZJ Grand Cherokee Forum 4 10-20-2005 06:31 PM
