WJ still overheating - JeepForum.com
post #1 of 25 Old 09-21-2009, 07:01 PM Thread Starter
G-Wagon00
I did all the steps that you guys had told me to try and it fixed it but not completely. I flushed the fluid, put a new thermostat in it, and put in a new fan relay switch. I still overheat though. Not badly just gets a little hot and will cool back down when i start moving again. It loses a little bit of fluid here and there and doesnt seem to be getting into the oil. Any thoughts on what it could be?
Looking for 04 Limited Grille, Tow Hooks for WJ(Rustys or OEM),.
nightcrew # 81
G-Wagon00 is offline
post #2 of 25 Old 09-21-2009, 09:07 PM
xJoshxx
2012 WK
how badly is badly? Stock 4.0L run 210 to 215 e-fan kicks on at 220
or could have air in the system.
mechanical fan clutch could also be bad.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 25 Old 09-21-2009, 09:10 PM
SwayzePDX89
2003 WJ
have you pulled up the codes?
SwayzePDX89 is offline
post #4 of 25 Old 09-21-2009, 09:19 PM
dougy147
Have you confirmed that the e-fan is working?
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
08 WK Laredo 4.7 (traded for tin can)
The Present
07 JK Unlimited Sahara
dougy147 is offline
post #5 of 25 Old 09-21-2009, 09:24 PM
SwayzePDX89
2003 WJ
If the fan is not working cause of relays.... and you wanna stop dealing with the pain of replacing fan relays 50 bucks a pop. I installed a switch and have step by step thread of how i did it. My jeep is free of any issues.
post #6 of 25 Old 09-21-2009, 09:25 PM
-cAcHe-
-cAcHe-'s Avatar
sounds like a fan issue...the highway air cools it down...so its pointing to the fan... maybe try and wire it up manually, thats how i have mine setup and its great.
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #7 of 25 Old 09-21-2009, 11:32 PM
owenswj
Yeh, but if his fan is coming on it may not be pulling enough air through. Maybe install a mechanical fan/clutch combo. I know the electric fan here in Vegas doesn't work worth a crap when its 100+ outside.
owenswj is offline
post #8 of 25 Old 09-22-2009, 05:24 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Could be a bad fan motor. I recently changed mine and took the old one apart. I had four brushes in the motor but one was worn down so much that it was not touching the stator. My fan would come on, but not spin fast enough to cool the engine.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #9 of 25 Old 09-22-2009, 07:18 AM
00RedWJ
2006 WK
I had the exact same problem. The fan was spinning but not fast enough to move air through the radiator and the car would overheat in traffic. Replaced the fan motor 2 years ago and the temp needle has never moved past dead center since. When the fan kicks on now you can feel the hot air being drawn through the radiator.
I believe these bad fan motors are drawing too much current and either frying the relays and burning up the plug that connects to the relay.
2000 Red Laredo WJ
4.0 with Selec-trac - Sold
2006 Black Laredo WK
3.7 with 95,000 Miles
00RedWJ is offline
post #10 of 25 Old 09-22-2009, 07:30 AM
xJoshxx
2012 WK
i hate that i get of my jeep with the a/c onand get a 120F blast of hot air lol
2011 WK2 ORA2 sold
xJoshxx is offline
post #11 of 25 Old 09-22-2009, 07:49 AM Thread Starter
G-Wagon00
It doesn't overheat all the time just everyonce and a while. Someone told me it was the head gasket or the heater core. Would that be a idea?
nightcrew # 81
post #12 of 25 Old 09-22-2009, 08:02 AM
00RedWJ
2006 WK
Does it happen when you stop at a light? or sit idling in traffic?
2000 Red Laredo WJ
00RedWJ is offline
post #13 of 25 Old 09-22-2009, 08:09 AM Thread Starter
G-Wagon00
No not usally. It hasn't done that since I replaced the fan relay switch
nightcrew # 81
post #14 of 25 Old 09-22-2009, 08:18 AM Thread Starter
G-Wagon00
nightcrew # 81
post #15 of 25 Old 09-22-2009, 11:40 AM
SwayzePDX89
2003 WJ
Have we thought about pulling codes when it over heats yet? X2
01 wj 4.0 overheating still!!! Nburns24 ZJ Grand Cherokee Forum 21 04-02-2009 11:35 AM
overheating dude979 ZJ Grand Cherokee Forum 7 03-20-2009 09:49 PM
Overheating ben98zj ZJ Grand Cherokee Forum 5 03-06-2009 02:05 PM
My wj is overheating. Forbidinworks ZJ Grand Cherokee Forum 5 03-02-2009 12:40 PM
Overheating JForestZ34 ZJ Grand Cherokee Forum 4 10-20-2005 05:31 PM
