#1 | |
WJ starting problem
I have a 02 WJ with the 6. 59k miles. When it has sat for a little while, at least 15 minutes or so, it takes about 6-8 seconds of cranking before it fires. If it hasn't been off for long it fires right up. Once on it runs just fine. I'm lost on what it could be, does anyone have any suggestions?
#2 |
When was the last time the spark plugs were changed ?
#3 |
not sure, i just bought it with 57k miles and now it has 59k. Thought i might do that and wires, but i was thinking if it was a spark problem, then wouldn't it be doing it every time i start?
#4 |
JEEP FREAK
Sounds like a problem with the anti drainback valve. When this goes bad, the fuel will drain down out of the fuel injectors & fuel rail assembly.
I'm not sure where its located on a WJ, but on a TJ, its part of the pump assembly in the tank.
98 TJ |
#5 |
I had the same problem. Finally a code popped up after two months. I had a Evap Leak somewhere. That was in fact the problem.
Now how i tested this was before i turned on the jeep, i would prime the fuel pump by turning the jeep all the way on and all the way off a few times, and then see if it started right away.
[B]99 WJ[/B] 4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS| Everytime Someone calls a Jeep, an SUV, [SIZE="4"]GOD[/SIZE] Kills a kitten. |
#6 |
whellin98tj - that is kinda what i was thinking, is there some way to test it?
madcabbie - so your saying if i primed it by turning it to on then off again a few times, and it starts, then it is a evap leak? thanks for all the help, -Kevin |
#7 |
Im not saying anything. Im an electrcian not a mechanic. I am just good at troubleshooting. So from what i know about the Evap System, and what was going on with my jeep, i came to the conclusion that the Evap leak was causing my hard start. Someone on here helped confirm it for me.
So i would say you could use my method to try and figure it out but it may not be true. But if it does work, i say take it to a mechanic and have them use a smoker to check for leaks. Hell id look around for a Technical school like a BOCES or Highschool that has a automotive class and have them do it. They usually have the testing equipment and its good expeirence for them. Plus ITS FREE...they will fix it for free as well, but i suggest taking it to a real mechanic for that.
#8 | |
JEEP FREAK
Let it sit for a few hours and then push in that schrader valve. If gas does not squirt out, the anti drainback valve is shot.
98 TJ |
#9 |
I just came online to research this problem a bit with my wifes Jeep she's having a hard time starting it too. Starts from the 2nd time every time. Pump was replaced under warranty with the old owners (I ran a full service history) and difficulty starting was listed.
I haven't tried to prime the car twice but sometimes after waiting a bit for the pressure to build up it does fire up a bit quicker. This weekend hopefully I'm gonna test the fuel pressure a bit and that drainback valve sounds pretty possible because once the fuel pressure is built up it has no problem starting. |
#10 |
well i let it sit for a while, and then pushed the tip of the vavle and no gas came out. I turned the key on/off couple of times, then rechecked and gas came out. Then i tried to start it in in fired right up. So what now, where is the vavle that stops the fuel from going back to the tank? On my brother's 91 YJ it looks like it is right on the end of the fuel rail. Not really sure what i'm looking for and i realize that his and mine are not exactly the same.
Again, thanks for the help. -Kevin |
#11 | |
Ok just got the TSB on that issue.. I'm not gonna post the whole thing, I could probably upload the .pdf file for you guys. Apparently one seal needs to be replaced before attempting anything else. A friend is gonna order the repair kit and it's $23CAN
I'll let you know how it goes. Neven |
#12 |
I have the same problem on my 00 WJ. Priming the engine by turning the key a few times before cranking does help.
#13 |
Found these 'Googling' hope they help. I got an extended warranty for my WJ when I bought it so Ima let them do it.
TSB#14-002-01 - Longer Than Normal Engine Crank Time Prior To Engine Start TSB# 14-05-99 - Fuel System Pressure Diagnostic Procedures |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
